Looking to buy my first Boxster - project
Hello,
I've seen an opportunity come up that I am thinking about taking. There is a 2002 Boxster S with 140,000 km for $4,000 CAD. I don't have many details yet, but apparently it is giving off significant white smoke. My research suggests the AOS. My question is, if the engine will still run, is there much risk of any further damage? Say I start it up at the guy's house, it seems to idle OK (perhaps a little rough), then I get it trailered to my house and replace the AOS. And probably the IMS too, since I don't expect to be getting any background info on it. Would anyone be worried about further problems? i.e. new engine?
Why start it up at all? I suspect your diagnosis is correct, but you run the risk of a hydra lock with that bad an AOS. I would simply flat bed it to your house, replace the AOS, clean the intake and then start it up.
I would negotiate with the seller that you could return the car and get your money back if a replacement AOS doesn't fix the smoke. It would cost you a couple hundred if you do the work yourself.
Hey Bekks,
I am assuming you are in the Calgary area. I saw the ad and followed up with the owner. He sent me this video showing the definite AOS issue. https://www.youtube.com/watch?v=Arct...ature=youtu.be. He also sent me two pictures with the engine out of the boxster, which is currently sitting in his shop, while the body is outside. I posted a similar thread in another Boxster forum and everyone said 'run away'. Would love to see follow up if you do go ahead with the project. Good luck.
@tdemo1 - That's the one. I tried to go look at it, but he had already sold it within a day or two of posting it. The price looked awesome if it was just an AOS replacement needed. He mentioned that a mechanic thought it might be the head gasket and my thoughts were that it was diagnosed by a mechanic that wasn't familiar with Porches. Definitely a bit of a gamble, but I probably would have went for it if the rest of the car looked good.
