Flat battery, cant stop alarm
2004 boxster s, electronic bonnet opening. flat battery.
read the book. Connected positive to red in fuse box and negative to door hinge. Alarm goes off and i cannot stop it. Tried all sorts of key turning and fob presses but to no avail. Bonnet will not open.
What do i do????
Also i read somewhere that all boxsters have the emergency cable, true or false?
Thanks.
What do i do????
Thanks.
What do i do????
Thanks.
What do i do????
Thanks.
There is an emergency front trunk release in at least some Boxsters. (Rumor has it early Boxsters *may* not have this -- I have no first hand experience with early Boxsters.)
I believe this is located in the passenger side (USA cars) front wheel well. You may have to remove some wheel well liner fasteners to pull the liner back enough to get to the pull.
With 12V power you can connect to a power lug in the fuse box that when pushed extends out. Ground is the door latch catch. This is emergency power just sufficient to open/close windows and the front or rear trunk latches. It is not intended to use to try to start the car or charge the battery etc.
Thanks for that. I shall search for the wire trip which i now think it has.
However, when i attach the external power as in book, using the key in the door does not turn off the alarm as per the book. Any other suggestions? Must be some combination of key turns in door or dash? Thanks.
https://www.pistonheads.com/gassing/topic.asp?t=1216621
(BTW, at the above site, I'm "Rockster".)
Here's a link to a thread about replacing a battery in a UK Boxster:
