Planning next years ASP build
Planning next to move my Cayman R from A-Street to ASP and looking for some input on bushings.
Where I am at:
I just got a pair of JRZ RS Pros, Swift springs, Tarrett front camber plates and Stromki Racing rear mono-ball mounts. I grabbed a Tarret 22.2 rear bar which I plan to match with the corresponding Tarret 26.8 front bar; also planning on Tarret end links.
I plan to add Wevo trans mounts as well.
Question I have is regarding bushings through out the suspension. While I have everything torn out to do the coilovers, it would be a good time to convert to poly bushings. Is this a worthwhile upgrade? Any particular vendors I should look into?
Thanks,
DJM
Where I am at:
Thanks,
DJM
I can't help you on the bushings. On the Tarett end links I liked the ones that I put on the front of my car. I also bought the dust boots to keep dirt out of the joints.
Where I am at:
Thanks,
DJM
Where I am at:
Thanks,
DJM
Poly will tend to squeak and bind when the lube gets pushed out. I'd consider the elephant racing harder durometer inner bushings - oem usability. Front is more important for steering feel, stiff rear bushings may make the back end too twitchy. One thing I was warned from bgb, if you do rear bushings, keep them similar in the control arm and toe link. One stiffer than the other will cause bumpsteer issues as they deflect and shift differently. Solid toe link, and rubber control arm -> bad. BGB can make you some delrin ones too, but they are a wear item and develop slop/play over time.
Cheers,
DJM
Cayman R has a ton of resale value and building an ASP Cayman is going to require a lot of effort. Would it make more sense to buy XPC5's Cayman and sell your R?
You may want to check out Powergrid endlinks. I have them on the rear and plan on purchasing them for the front.
http://www.powergridinc.com/swaybar.asp
Also, I actually do very little autox -- for the purposes of classing, my hillclimb club uses SCCA solo classing. So I am trying to build a good hillclimb car, within the confines of SCCA rules for SP.
I've already done quite a few mods, in a similar vein to XPC5:
BGB PDK trans cooler
Mantis Deep sump extension
RSS harness bar and Schroth harness
Tarrett Rear swaybar 22.2mm
Coilovers: Full JRZ RS Pro
GT3 brake master cylinder + steel lines
Front GT3 brake ducts
Pagid yellows
Bulletnose wheel studs
Remaining mods I am looking to perform:
Front swaybar
Swaybar endlinks
Wevo trans mounts
Light weight battery
Bushings?
That's *ehem* only about $2k of additional mods.
And of course there are wheel and tires, but I'd need tires no matter what class or car I am running.
I ready have fairly light seats -- the GT2 seat are 39ish lbs with the sliders hardware. The R's PDK already has an LSD, albeit no where near as effective as the Guard unit, but that mod will have to wait a bit. Likewise, I am not quite ready to dive into intake/headers/exhaust/tune...yet.
I suppose if I really wanted to help fund my build I could sell the GT2 seats and Spyder wheels -- that would generate about $10k, then I could go for the intake/headers/exhaust/tune!
Cheers,
DJM
Another follow-up (I am just getting around to install the suspension, 2 moves and 2 jobs changes, life has been a bit crazy):
I am looking for a clarification on your comments on solid toe links and rubber bushings in the control arm. I will be using solid toe links (Tarett), but I currently have OEM LCAs and do not really plan on using GT3 style LCAs, at the moment. According to the input you received from BGB, I should replace the rubber inner LCA bushing with 'monoball bearing' bushing or a Delrin unit from BGB. Is that correct?
Also, what about bump steer compensation for the front end?
Thanks,
DJM
Hi XPC5,
Thanks,
DJM
Thanks,
DJM
-Mark
