Autocross and PSS9
I run PSS9's couple suggestions:
- best mod (already had Pss9's too) racing seats. These helped my times more than r-comps or hoosiers, you feel the car starting to step out so much sooner, so you can use it vs. just try to save it. completely changed the feel of the car. You would be shocked at how much you are bracing yourself with normal seats. Before the seats a spin would start to happen before I noticed and by that time it was a heroic effort just to save it. Now I know soon enough to make minor inputs to keep it from going around.
What I am very quickly realizing is that I need to learn to drive.. The tweaking will never stop, but I have a feeling that I am just not breaking enough.. Its mental.. slower into the corners could actually be better times..Period..
Thanks to all for all the comments.
tomorrow is renegade miata club running, i am not sure if they accept drive-ins but i do not think they will send you away, I plan to be there if you want to come just tell registar you are from NCR PCA.
Just to add to the confusion, several comments above seem strange to me. I don't know about PSS9 settings (but I sure like Bilsteins), but I thought it was common knowledge to set the front a bit softer than the rear for autocrossing. When I stiffened the front without stiffening the rear, I get more understeer. Which brings me to the second point. For autocrossing, I prefer a little oversteer to understeer. A little oversteer scares me on track (especially in fast sweepers), but it seems to work fine on an autocross course. I agree with the point about even pressures front and rear working well; at least on my car.
For better rotation we run our front tires 4psi higher than the rears. There are several great handling charts you should print and carry with you in the car to review while on grid. Roger Kraus Racing has a good one.
