NJ-GT Please explain this.
Photo in by Dan Mull, BMW club pro photo. Takes pics at many autocross events and track events around here.
I lost one event (came in second) because I got air and one boost hose came off
on landing, 2 corners from the end and the car went into limp mode.
...ok...maybe not.
Yes, it was a bit bumpy in places. This was a case of the local PCA chapter holding a weekend retreat in the interior of BC. The mall was kind enough to let us use their parking lot and it was bumpy, sloped, irregularly shaped and covered in grit. Definitely far from ideal. However, the course designer did a fantastic job with these challenges and made the most fun course I've ever driven.I had worn Kumho V710 on the car and the grip was dicey most times on the slick surface. Add on bumps and the car was dancing on the edge of spinning most of the run. I was "in the zone" that day and had a blast. Parts were like this:
Heading into the stop box was a right and then left into the box. Doing the right turn at high speeds meant the rear of my car broke loose and started to slide. I had to drive in a way to get traction back and reel it in to make the left turn into the box without smacking a cone by going in sideways. It felt great to accomplish that.
Another time where the bumps showed up was when our guest speaker, Ross Bentley (Speed Secrets author), drove a 997 Cup car and that car was so stiffly sprung on the bumpy course it was hopping all over the place, even as much as a full car width sideways in the air. Ross really knows how to drive and kept it under control.
I gave Ross a ride on my last run and then tossed him the keys to my car. He promptly beat me by 0.5 seconds.
Cheers,
You can minimize front wheel lift by increasing rear spring rates, but then you need to balance the front with stiffer rates as well, and eventually the car would be too stiff for road or autoX use.
