autocross and radiator damage
Old 07-28-2008, 03:02 PM
kpl
kpl's Avatar
Default autocross and radiator damage
anyone other than me break the lower hose fitting on a radiator on their car autocrossing? I mowed some cones and must have caught one or two just right to force one up into the lower radiator hose, breaking the radiator. It cracked at the hose fitting.
Seeing if anyone has come up with something to prevent this from happening again before I reinvent the wheel and design something myself.
Old 07-29-2008, 12:02 AM
Jim Michaels
Jim Michaels's Avatar
Driving lessons?
Old 07-29-2008, 08:43 AM
Mussl Kar
Mussl Kar's Avatar
Not yet. Front splitter of the GT3 RS mostly slams cones to the side because it is so low. I don't ever remember getting one under the car. Got some dents/scrapes in my rocker panel from an agricultural experience last Saturday though. Apparently some big pieces of loose asphalt lurking in the grass at Devens.
Old 07-29-2008, 03:50 PM
David A
David A's Avatar
Cargraphic makes beautiful radiator grill protections.
Old 07-29-2008, 05:50 PM
kpl
kpl's Avatar
David- unless I'm missing something in their product lineup, which is entirely possible, I don't see anything that addresses the underside of the car. The lower radiator hose attaches on the lower, back side, of the radiator.
Old 10-10-2008, 10:39 AM
ritzblitz
ritzblitz's Avatar
Go away you turd
Old 10-10-2008, 10:51 AM
StickShift964
StickShift964's Avatar
check his other two posts, I think wikipedia has a spam-bot
Old 10-13-2008, 03:02 PM
Kerry
Kerry's Avatar
Yes, I had the same thing happen. My 996tt is fairly low, and a short cone just popped up in that space once. Lucky me. I haven't tried to make a bracket to block that space.
Old 10-14-2008, 12:37 PM
kpl
kpl's Avatar
Here is what I came up with:
more info and pics here
Old 08-15-2012, 04:12 AM
BuddyK
BuddyK's Avatar
I just had this happen to me tonight.
I hit some cones at autocross and radiator spewed fluid.
I had to get the car on a flat bed tow truck and taken to the dealer.
Any ideas what I am going to have to pay to get this fixed? I'm wondering about this.
It's a 2010 Turbo
Old 08-15-2012, 09:46 PM
sjfehr
sjfehr's Avatar
It this an issue that only afflicts 996 turbos?
Old 08-17-2012, 10:08 AM
balefire
balefire's Avatar
this has happened to multiple 40th anniversary 996s which also have the turbo front.
https://rennlist.com/forums/996-foru...and-faq-8.html
Old 05-14-2014, 02:30 PM
balefire
balefire's Avatar
this just happened to me. =( sigh.
any other pics of ways to protect the radiator?
how much is this going to cost me?
Old 05-15-2014, 06:42 AM
sjfehr
sjfehr's Avatar
UGh, that sucks Fortunately, it will clost you a lot less now than 10 years ago, thanks to every day coolant tech catching up to porsche specs, and being able to just grab a couple $10 bottles off the shelf of your local big box/auto store vice the insane porsche tax.
I don't suppose it's something you can fix with a little jb weld?
Old 05-17-2014, 11:14 PM
Mussl Kar
Mussl Kar's Avatar
Stop hitting cones. Bwa Ha Ha! I hit one or two cones per season with the front of the car. But the fat *** of the RS often nips them just with the rear tire. Not even hard enough to hear but they sometimes do fall over. And then again I sometimes tickle a lot of cones causing a lot of workers to run and adjust.
Quick Reply: autocross and radiator damage
