Funny Noob Comment at an AX
Riding a rev limiter common is something I have not ever seen in PCA GGR AX. There is a difference if you don't upshift and keep in a higher rev range. Maybe it is fairly common for people that don't now how to shift or a Boxster thing.
The one time I hit the rev limiter at a DE my 996 (was trying to pass another car), the fuel cutoff was severe and it took a second to recover. If it was a AX, I can't see how 'riding rev limiter' can help.
I tried first gear on a few of those slower sections at that UFO event and quickly bounced off rev limiter but quickly adjusted to use 2nd gear . My problem wasnt with my motor however I broke a CV Joint at the event - really strange as rear end of the car was bouncing around prior to CV joint failing making the car handling terrible - the entire half shaft had broken free when it let go.
Talk to the 914 drivers at GGR events Lots of us occasionally bounce off the rev limiter for short periods of time at some GGR and UFO events. You are absolutely right however. If you are spending lots of time on the rev limiter you are going to be faster just shifting to the next gear. Some 914 guys are afraid to make quick shifts up and then back down with our old 901 gearboxes. LOL!
Touching the rev limiter briefly really is no big deal. I misjudge ocassionally, I'll see you on the 17th GGR event. Don't think I will attend th UFO event on the 4th so I can put in a new suspension.
Does anyone set their limiter lower for these events? My MSD is set to limit revs at 6500 but I could change that in a jiffy.
