Autocrossing with Avon slicks...
Hello.
Is anyone running the Avon slicks?
Hoosier stopped making the sizes I need (15's), so thought I would give them a try.
Running the 'hillclimb' compound that is supposed to comparable of a compound between a R25 & R35...
Anyway, any ideas of what kind of air pressure and how much camber these like?
Thanks.
Thanks.
Put a lot of- camber up front, those tires like to overheat and blister on the edges. My friend with his STI had problems with those tires on the front only because he needed more camber and probably needed to cool them off with water after each run. Really sticky tires though!
