Reducing rear tire pressure reduces oversteer?
Car is a 944S2, caged, 400# front springs, 30mm rear torsion bars, 30mm front sway bar, 20mm rear sway bar. Toed-out in front a bit, toed-in at rear a bit, camber of -2.25 front, -2.75 rear
Last year, the car was set up, aligned, and corner-weighted for track with 245/45x16 on 7.5" rims front and 265/45x16 (tall!) on 9" rims rear. V710's all around. As one would expect, safe, predictable understeer, with equal tire pressures all around (34 psi). My primary objective last year was time trials, and the car was perfect for that.
This year I decided to get V710's only for autox, and put 215/40x16's on 7.5" rims all around. No other changes (yet). I started with 38psi cold all around. First event was last weekend, the course was full of slaloms of various kinds (offset gates, tight, open, equal length, decreasing length, etc. etc.). First run had some oversteer, but I use the first run to find my way around. Second run I changed nothing except I went for it, and had oversteer on corner exit, and some at mid-turn.
Now I forgot to bring my setup cheat sheet, and I never remember to add or subtract pressure. So I thought, lower rear pressure, rear tire gets more grip, ergo less oversteer. I dropped the rears by 2 psi, and, on the next run(s), I could put the power down nicely. Of course, I put down so much power that I went in too fast in a section and screwed up, but that's beside the point.
I get home and read I did it backwards ... I'm supposed to have raised the rear pressure to decrease oversteer.
Yet what I did ... worked ???
Where's our brain trust?
I also did a run in my new street tires (RE050A PP, 245/40x17 all around, 36psi) and the car (as expected) does oversteer. I'm changing sway bars to try and tune the oversteer out in that case as well, so we'll see.
Still plays with cars.
Best,
Bob
More/less air can create understeer or oversteer depending on what part of the pressure vs grip point you are at.
In my race car I target my hot tire pressues at what I believe is their optimal grip. I don't use them to balance the car since any change in pressure wil reduce the tires grip. In stead I chose to adjust sway bars since this does a better job to shift balance and maintain my optimal tire pressure.
I too had the same experience. I was starting with the tires at about 36 cold which brought them to about 41 hot. One guy showed me that there are arrows on the sidewalls and that I can use the tire up to that point. I lowered the cold pressure to about 32-33 and it has increased me rear traction greatly. I still have not reached the arrows so I can take more air out if I want. By the way I am using the V710's also.
P.S. Dan I plan on posting laps 5 sec or more better than yours next Sunday !!!!!!!!!!!!!!
Oversteer - decrease rear tire pressure.
soften rear sway bar
soften rear shocks
stiffen front sway bar
Understeer - decrease front tire pressure
soften front sway bar
stiffen rear sway bar
soften front shocks
It can be summarized simply, to add grip soften the end of the car that needs more. Ross Bentley also points out that you should never use more roll stiffness than you need because body roll transfer weight to the outside (loaded) tires for more grip.
Naturally everything is a compromise and a track with a lot of fast transitions (autocross comes to mind) will call for more roll stiffness than a circuit with a lot of sweepeing turns.
Best,
Understeer
... and Porsche, who raised the recommended rear pressure for my car to 44psi (front 36psi) to reduce oversteer.
However, the idea of being on one side or the other of the grip/pressure hump makes sense.
As for Tremblant, I thought only GT3's were allowed in RSR events?
Seriously though, I'm going back to Targa Newfoundland in a few weeks, and that's where the budget went this year. (Last year it was the Parade.) I may do some PCA DE next year, but Tremblant just isn't cost-effective for a non-instructor not-at-many-events time-off-during-the-week-costs-money person like me.
M758: you're right, but this was the first time on this tire size, so I went with everything as-is to start. The car exhibited a lot less oversteer with 245/45x16 RA-1's on 9" rims all-around, but the V710's (and the different sizes/rims) seem to behave differently.
Energy9: You're right, but I ran out of talent 8 years ago, and it ain't coming back. Hack away I must.
Here's a few seconds of my first run that someone video'd, i.e., "where-the-h*ll-do-I-go-next" http://www.seko.ca/SII30Jul2006.wmv (right-click, save as ...)
Car will be according to the rules, will pass tech with flying colors, and 5 sec is probably conservative.
