Cayman in STU, anyone else? questions...
Unless it won't fit, I'll be trying this this weekend at a local on my 987.1 Cayman. I need to fit check the 295/30-18 Yoko on the rear as it's what I plan to run at Nationals to find out if I need a different spacer thickness. (I will never run Bridgestones at Lincoln again.)
My issue with the Stones is that once they get a little hot, heat management in the front becomes difficult in that while you can lower the surface temps, the carcass of the tire seems to draw/keep heat from the brakes or blow off from the engine air cooling ducts. For a single driver, that can be managed but it becomes much more difficult for two drivers especially at smaller events where turn around is tighter. Thus, I am running Yoks this year which don't like hot either but at least they don't also grab OPR. I know AS is TU/WED (much less OPR) and based on last year when AS was 5th heat, I'm betting on earlier heat in cooler conditions.
Quit Smokin'
I haven't had that with the stones yet... It's odd that you mention this because at the CAM challenge in Peru I ran my fastest times of the whole weekend in the 2 warm up runs for the challenge. I let my wife go first so she wouldn't have heat soaked tires, but I think they ended up being a little faster after they were hot. I was never able to get back to those times in the subsequent rounds of the challenge after they iced us (it seemed odd they way they moved around between classes)
No. They have announced run days but not the run/work order. The list you are seeing is simply which days the classes will run, but..., from past experience, it seems very consistent that if a class runs late one year, it is more than likely it will run early to mid-day the next. YMMV -- There is no rule per se this is how they set run order. Much of it is balancing the drivers and workers. If you haven't gone, you have to plan on crazy weather shifts (it can be hot as hell with ambient's approaching 100, it can rain like Noah is preparing the Arc especially the pop up storms late afternoon, it can be very cool in the mornings), having shelter to get out of the sun, rain, wind, etc., There is definitely strength in numbers -- ie plan on paddocking with your TX region. I paddock and run with the Chicago/Milwaukee regions so I'll see you at the JXB icecream social/whisky tasting.
Patstat (06-18-2024)
Lot's o' Pcars in STU at Nats this year...
6 out of 25 entrants. I'm the only 981 base...
Hopefully the tow rig will be done in time...
Z3papa (06-30-2024)
Only two 911s in the class this year, myself and a GTS (jealous, heh). Excited to see how it all works out and compare notes if they've done anything different.
Abt12 (06-26-2024)
Be thankful though, Bob and Billy Davis were chatting with me last fall because they were considering buying one to campaign in AS! Seems like they didn't do that (yet, anyway!)
