Speaker repair
Speaker repair
One of the original rear speakers in my 968 is rattling. I would like to get it repaired. Any suggestions on where? It is an original Blau unit used in the later 944s as well. Should I look for a used one?
Don't know if he does smaller speakers, but his work is excellent. Can't hurt to call.
http://www.nealspeakerrepair.com/about.html
If it's the rubber/foam around the rim and the cone is ok, then yes, google "speaker surround kits"
If you need a new woofer, then (assuming the whole speaker was well designed) you need some care in matching the parameters of the old one. That might be hard unless it has a model number or there's a listing for your speaker.
Here is an example, ther are plenty of others. If you know the size of your cones you should be able to match.
http://www.simplyspeakers.com/speake...e-it-kits.html
