Turn my car on and no sound is coming out of the speakers. Nothing from the radio/ipod/navigation/ or even calls received over blue tooth.... Only the park distance sensor makes a sound (not sure if this is a different speaker).
What is strange is that my PCM will not allow me to select specific sound options like adjusting the linear sound, when I press the check box nothing happens.
Also when I select a source such as FM it will still say AM in the bottom portion of the screen (see image). When selecting other sources nothing seems to happen.
Not sure if this is an amp issue or a PCM issue. I have PCM 3.1 running the latest version 3.43.
I have tried pulling the fuse out to reset, doing a hard reset, etc.....
Anyone ever have this issue and figure out how to solve it?
