Air conditioner compressor doesn't start after coolant pipes job
Major overhaul with coolant pipes including sharkwerks elbows, all new hoses and radoators, new clutch kit fron kevin, bbi slave, motor mounts intercoolers. Plugs annd could one turbo actuatot one variocan solenoid valve gmg exhaust.
first warm day no AC . Fuse ok but had to replace fan fuse (was working after maintenance though)
is there anything liklt left unplugged that i can check? Looking for areas to check or diagnostuc tests.
Regards
Colin
2007 997 Turbo
Regards
Colin
2007 997 Turbo
Colin,
Did the shop swing the A/C compressor to the side? If so is the A/C clutch wire connected?
If they evacuated the charge and disconnected the A/C lines>> do you have a freon leak? Low pressure will cause a fault and clutch will not engage.
