Replacing Dual/Tandem Pump & Workshop Manual for 2007 997 Turbo
Hi
My first post, ive been reading for a while. I've owned and worked on lots of aircooled 911's but a 997 Turbo is a new toy, and completely new territory.
Its a 2007 997 Turbo (3.6)
I need to replace the dual/tandem pump on the left side of the engine. I would really like to read a procedure in a workshop manual first, but i can't find one. I have allready bought a few manuals from ebay, advertising that they cover the turbo, but they don't actuall seem too.
So two questions :
A) Workshop Manual (with tandem pump procedure)
I'm more than happy to pay for a workshop manual (i.e pdf/link) which covers the turbo models and specifically with a procedure for the dual tandem pump replacement
B) Alternatively - anyone suggest a "procedure"
Do I need to remove the exhaust? Can i do it all from below? I can only see two torx bolts on the bottom, and looking at the PET can see two more above, but can only just feel them.
How do i remove the vac line connection? Will i need a new vac line,etc.
Basically anything you can tell me and im all ears!!
So two questions :
Are you replacing it because of corrosion? You can now get this cover as a stand alone item from 9meister:
https://rennlist.com/forums/997-foru...l#post11994643
AMGo (05-09-2020)
Hi No in my case, the pump is worn out.
I would really like a workshop manual, i always prefer to read up on a procedure before i do it. Any idea where i can get one, the usual ebay links have not been fruitfull so far
So i have found that alldatadiy.com has a manual for the 997 turbo, the procedure for the tandem pump removal is under oil pumps. I know understand the vacuum connection unbolts. I'm posting this info for anyone else that needs to know. I have subscribed and confirm that it does cover the model, which is good news, i hate working blind!
I still have the questions of what else i need to remove to get the tandem pump it, i.e exhaust, parts above it, drain oil, etc? This isn't covered in the manual.
I guess im just going to suck it an see!
WM 171919 Removing and installing oil suction pump
Tools
Technical values
Preliminary work
WARNING
Hot fluid
--Wear personal protective gear.
Component overview
Removing oil suction pump
Removing oil suction pump - cylinder bank 4-6
CAUTION
Ingress of dirt
--Lay removed engine parts on a clean base and make sure to cover them.
--Use the cover for dust protection when fitting the engine NR.165 on the engine assembly support.
Loosening screw on oil return line
Threaded joint for oil suction pump
Pulling off oil suction pump
O-rings on oil suction/tandem pump
Removing tandem pump - cylinder bank 1-3
CAUTION
Ingress of dirt
Vacuum line on tandem pump
2.2. Remove old O-rings.
Tandem pump, cylinder bank 1-3
Installing oil suction pump
Installing oil suction pump - cylinder bank 4-6
CAUTION
Ingress of dirt
Information
Fitting oil suction pump
-- Tightening torque: 10 Nm (7.5 ftlb.)
2.1.Turbo only: Secure holding clamp for oil line to the pump with an M6 Torx screw. -- Tightening torque: 10 Nm (7.5 ftlb.)
CAUTION
Ingress of dirt
Information
1.3. Turbo: Secure holding clamp for oil line to the pump with an M6 Torx screw. -- Tightening torque: 10 Nm (7.5 ftlb.)
Information
Subsequent work
Driving off while the vehicle is on the lifting platform
This is everything you need to know
Tools
Technical values
Preliminary work
WARNING
Hot fluid
- Danger of scalding
- Drain engine oil.
- GT3 only: Unclip vacuum line for exhaust valve on lower engine carrier.
Component overview
CAUTION
Ingress of dirt
- Danger of material damage due to blocked oil bores/oil ducts.
- Remove oil return line on the pump neck.
- Unscrew three M6 Torx screws -1- .
- Pull oil suction pump out of the cylinder head.
- Clean sealing faces (with a clean cloth soaked in acetone) and replace O-rings on the pump -1 and 2- .
CAUTION
Ingress of dirt
- Remove vacuum line for brake booster -1- on the tandem pump.
- Unscrew three M6 Torx screws -2- on the tandem pump.
- Pull off tandem pump on the cylinder head.
CAUTION
Ingress of dirt
Information
- Replace O-rings.
- Grease O-rings with a light coating of Kluber Syntheso Glep (Part No.: 000.043.204.68).
- Fit oil suction pump with new O-rings on the cylinder head.
- Fit three M6 Torx screws -1- by hand and tighten them.
- GT3: Clip in vacuum line for exhaust valve on the support.
CAUTION
Ingress of dirt
Information
- Replace O-rings.
- Fit tandem pump -1- with new O-rings on the cylinder head.
Information
- Replace O-rings.
- Fit vacuum line -1- for brake booster on the tandem pump.
Subsequent work
- GT3: Clip in vacuum line for exhaust valve on the engine carrier.
- Fill in engine oil.
- Risk of squashing
- Risk of damage to components
- Allow the engine to warm up on the lifting platform and check the pump for leaks.
Robocop305 (01-19-2022)
Thanks for the procedure. That was really cool! =)
If anyone else needs to know, you can remove the tandem pump without removing or draining the cooling system pipes, and the exhaust/rear engine mount bar. Its a bit tight, but you can get to all of the bolts.
no problem anytime
yeah the bad news is yes you do end up stripping down the back end of the car! shame the pump has actually gone as alternativecarparts actually make a replacement tandem pump cover for the turbo complete with new rubber washers which Porsche do not sell without a new pump...
