997.1 oem fire extinguisher mount
Anyone know if there is an aftermarket extinguisher that will fit the oem tray/bracket?
Even if an oem were available I'm sure it would be overpriced.
I found the oem bottle at SunCoast and the price was out there. I'm going to try a H3R Halguard 1.4 lb bottle and see how it fits. On paper it looks like it will fit ok. I'll update after I try it out.
The H3R 1.4 lb bottle ended up not being a good fit. I removed the oem bracket, drilled a new hole in the H3R bracket and that worked out nice. I don't know if the flat mounting plate under the front of the seat is there on cars that didn't have this option from the factory; probably not.
Fire Extinguisher
Is this item still for sale? If yes, I would like to buy it....if no....does anyone have a Gloria 1kg fire extinguisher for sale like the one above?
thank you,
Ben
thank you,
Ben
