Bad news after oil change.
Macster, you forgot one detail. He is getting a DME crank position error. There is too much slack in the chain and the ECU is throwing codes.. What is worse, if the rail is delaminating plastic it is packing the oil pump screen and is scoring the vaned suction pump gear set. More important is the chance of plugging up the oil filter which will put the engine oil circuit into bypass. This will then push plastic debris into the tiny piston squirter (plug them) and plug the hydraulic intake lifters and foul the vario cam module vanes.
The best thing would be to remove the waterpump console and remove the variocam covers to inspect the 4 rails, check the condition of the timing chains and sprockets. Best is a term to hedge your bets and risk.. Best is a cautious opinion.
But my reference, granted for a 996 Turbo, but I think it applicable -- well, given the gravity of the situation probably not but the OP's going to have to rely upon his tech not me anyhow -- gives only one crankshaft position error code: P1579.
P1579
111 Crankshaft Position Sensor Signal Implausible Diagnosis conditions
• Engine running Possible fault cause
♦ Corrosion in the connector
♦ Loose contact
Now if he were getting P1324 (Position of camshaft in relation to crankshaft, Bank 2) or P1340 (Position of camshaft in relation to crankshaft, Bank 1) or possibly even P1341 (Camshaft adjustment, Bank 1) or P1342 (Camshaft adjustment Bank 1, output stage) or P1343 (Camshaft adjustment, Bank 2, output stage), would have me more in agreement with you.
Just so it is clear, I'm not in total disagreement, mind you.
My goal is to provide the OP with some hopefully input of value to add to what he knows/what he learns from others here and from his tech so he ends up with a clearer idea of what's probably going on and can make a more informed decision.
And last but not least, it is because of the gravity of the situation, what's at stake, that I advised him that he was going to have to rely upon his trusted tech for his counsel and advice. Not me.
Bottom line here is that confidence in the motor has been eroded. It's just a matter of can you and/or are you willing to locate the funds to do a total repair. Chain,sprockets guard etc.....there are also " while you're in there" repairs such as clutch, brakes etc.. If possible.
NMB to tell people what to do ....but if you can afford and will keep the car I say go for it.
Took the car into the shop today and had the DME read and oil filter checked. Camshaft deviations were within normal limits. Bank one 2.85. Bank Two 2.53. So apparently the chain did not slip. Inspected the oil filter. There was one smaller piece of debris and 3 or 4 tiny specs in the filter pleats. I read the revs. I have 5 range four, 1 range 5 and 1 range 6. The 5 and 6 revs were done early in the cars life. Well before I owned it. Still working on a plan to replace the rail or rails.
The information gives you a better idea and gives you a little breathing room. The DME overRev reading of 1's at 5 and 6 most likely are a glitch..
If you must drive the car before bore scoping the rails (or fixing), please check your oil filter in two weeks for material.
