Spun camshaft
#31
Well after driving a Macan S around for nearly 3 1/2 weeks I finally received my car back and although I must say I did thoroughly enjoy the Macan S I was ready to get my car back. All I have to say is thank god for my Hendrick Guard aftermarket warranty coverage, they covered the repair 100% outside of the deductible which was only $150 out of my pocket (total was ~$8500). I originally paid $2500 for the powertrain aftermarket warranty 4 years 50k miles. Obviously the warranty has paid for itself almost 4 times over. The claim was seamless and they didn't blink an eye when it came time to pay the dealership, I'm thoroughly impressed in Hendrick guard warranty.
They also let me keep the old camshaft just incase I have this failure in the future I can have the old cams pinned, but I doubt I will have the issue in the future being that both sides have been replaced.
What makes you think the problem will not come back? The cams you reinstalled are OEM and unpinned correct?
#32
Good to hear your warranty covered the repairs even though you had mods. Did you remove the mods when you took the car in? If not, did a rep from the warranty company inspect the car?
I did not remove the tune or exhaust, and yes Hendrick Guard warranty company did fly a rep out to inspect the car but my service advisor told me they were literally there for 10 mins (rep looked at the failed camshaft and said ok repair it.) very seamless. It also does help to have a relationship with your dealer as I was very upfront with the dealer and told them I had an aftermarket tune and exhaust and they said no problem. You have to think if the dealer was upfront with the warranty company and said hey this guy has a tune and exhaust on his car they would immediately deny the claim which would result in no repair and lost revenue for the dealer.
#36
I just looked at my invoice and they don't break it down with that much granularity. It was a package price so unfortunately I can't tell you what the machining and pinning cost by themselves.
#37
#41
Successful actuator swap and no CEL with 60miles on the clock so far. Will update if it pops back. Car is running way smoother now. I think the old actuator was malfunctioning even before the CEL was triggered. My idle had gone to **** over the past few months that it made me think my mounts were bad.
#42
#43
#44
Dreaded Spun Camshaft??
Car has 33k miles....on way home from work, car had massive misfire. Limped home on 3 cylinders. Scanner showed:
P0300 Multiple cylinder Misfire
P0301 Misfire Bank 1
P0302 Misfire Bank 2
P0303 Misfire Bank 3
P0016 Camshaft position correlation Bank 1
P0011 Camshaft position timing over advanced Bank 1
Praying it is a defective camshaft solenoid/actuator.
2007 911 turbo 6spd
2007 911 turbo 6spd
Last edited by Ttmspt; 07-22-2016 at 12:31 AM. Reason: Forgot to mention make/model of car
#45
Car has 33k miles....on way home from work, car had massive misfire. Limped home on 3 cylinders. Scanner showed: P0300 Multiple cylinder Misfire P0301 Misfire Bank 1 P0302 Misfire Bank 2 P0303 Misfire Bank 3 P0016 Camshaft position correlation Bank 1 P0011 Camshaft position timing over advanced Bank 1 Praying it is a defective camshaft solenoid/actuator. 2007 911 turbo 6spd
