Tire size question
Tire & wheel fitmet question
Hello Rennlist,
I'm looking for information on RE71R's in OE sizes for a 997.2 tts w/CL wheels. I'm also lowered on GMG springs.
After searching it seems OE sizes are not available. Are there acceptable alternative sizes, for example 245/315 etc. using OE wheels? Recommendations on other tires that are outside the OE sizes are welcome, too.
I'm not opposed to OE sizes, I'm just trying to understand what I can get away with using OE wheels, safely.
Primary use will be AutoX and track. I have another set of wheels for DD duty.
Thank you!
Thank you!
Wondering the same thing about MPSS....is it because the Michelin PS4 is on the horizon?
http://www.michelin.co.uk/tyres/michelin-pilot-sport-4
Loks kinda like the PSS and PS2 combined but then again may be in a different rating
I think I have this narrowed down. I decided on new wheels instead of using OE wheels for the track. Can someone please check my configuration? Also, keep in mind that I am lowered on GMG springs.
Size: 19x9 Offset: 47mm (front)
Size: 19x12 Offset: 48mm (rear)
I'm looking at 245/35 325/30 tires.
Many thanks!
Many thanks!
