recirculation valve question
So this has been discussed ad nauseam weather or not to switch the stock plastic recirculating valves on a stock car with the billet ones or not. (general consensus is no BTW).
Someone said it "deepened" their exhaust sound.....
I cannot understand how this would be possible. Maybe someone smarter than I can explain how it would do this. After reading about it, it seems it would have nothing to do with the "sound".
I only present this question because I'm changing plugs and coils and have been staring at these damn valves for a while now.
JC
JC
JC
JC
Hope that helps/confirms your thoughts...
DC
The factory valves work good.. Similar units in the 997GT2 >> tuned will reach pressure levels over 1.5 bars..
If you have a valve the seizes>>you risk turbine shaft breakage/sheering.
