Function First vs Numeric Opinions wanted
Did some searching and nothing specific popped up. So for those who've looked at both, and obviously assuming both solutions offer an improvement over stock, what are the pros and cons of the Function First shifter solution vs the Numeric Racing shifter solution? Other than price obviously. Does one have advantages over the other, or does one feel better shifting than the other? Does one last longer or wear out sooner or later than the other? Reason being, I really don't like the notchy feeling going into 1st and 2nd.
Thx
Mikey
Thx
Mikey
I actually really like my factory short shift.
I've started to wonder if there's something that broke on the cars where folks feel like they need to go to something beyond stock.
That said, the Numeric shifter is a beautiful piece, if I installed one, I'd have a hard time putting a boot over it.
I have a Numeric shifter with a Function First ****, IMO a perfect setup. All of the factory shifters (and *****) are plastic whereas the Numeric eliminates any flexy, creaky aspects. The combo on my car truly epitomizes the rifle bolt cliche.
I kept the stock cables as that is not a very DIY-friendly procedure and I've heard lots of stories of excessive noise of the unpleasant variety vs a minor functional improvement.
I could see that replacing the factory plastic bushings/bearings with metal would help with the fluidity of operation and with durability, but the Numeric is on a different level being an entire upgraded replacement unit.
I have the function first parts, and I'm pleased with it, but have no experience with numeric.
The numeric will likely be a step more direct and solid, but there is also a pretty serious price increase.
If you generally are ok with how the car shifts, the function first upgrade might be the way to go.
any shifter that has a plastic housing is going to be inferior to an all billet aluminum frame amd heim joint bushings and roller bearings on the shifter shaft.
the numeric is much higher priced because tis a far superior shifter to anything on the market with the exception of a cae or sequential which is again a huge increase over any other setup. its just that simple
Just found that cargraphics has an adjustable ball bearing shifter VERY similar to numeric. Looks almost identical. Tempting since that would mean no import tax or shipping cost for me
Sounds very reasonable. It would just be interesting to get a measure on the difference, which would of course be subjective.
Thanks for all the opinions guys. I ended up finding a nice used Numeric on eBay that I snagged for a great price. I sent it to Numeric for a thorough going over to replace any worn parts before installing. $35 to replace all 6 ball bearings and it's good as new. Great folks to deal with btw.
Cheers
Mikey
Cheers
Mikey
I have a hard time picturing much wear on ball bearings in a shifter. OTOH you're chasing the absolute best feel here, and $35 is at most noise in this game, so I'd almost certainly have done the same. Still, I bet the old bearings were fine.
I'm very curious about how much nicer the numeric might be. I do get a lot of joy out of how nicely my car shifts. Certainly more joy than I get out of exactly how fast it is.
Some searching brought up another approach:
Cheers
Mikey
Actually yes, they were in need of replacement. There was significant axial play in the front bearing on the main shaft for side to side pivot. You could take feel distinct clunking on the shaft when grabbing the gear lever and lifting straight up and down. Also at the clevis pivot section where the actuating shaft rides in the slotted section of the clevis as the gear lever is moved side to side, noticeable play here as well.
