997 Turbo Forum 2005-2012
Need 997.1 Turbocharger
Old 11-03-2015, 09:38 PM
TNR911
TNR911's Avatar
Default Need 997.1 Turbocharger
Hello all,
My left turbo has worn out and I need a replacement. Porsche is now charging 4k for rebuilt 997.1 turbochargers. Does anyone know of a reputable, quality shop that could do a rebuild and/or have a line on OEM turbocharger stock?
Thanks in advance.
Old 11-03-2015, 09:49 PM
vr6tee
vr6tee's Avatar
I have both stock turbos with 8000 miles on them. Pm me if you're interested.
Old 11-03-2015, 10:17 PM
TNR911
TNR911's Avatar
PM sent
Old 11-03-2015, 10:57 PM
shadow993
shadow993's Avatar
Originally Posted by TNR911
Hello all, My left turbo has worn out and I need a replacement. Porsche is now charging 4k for rebuilt 997.1 turbochargers. Does anyone know of a reputable, quality shop that could do a rebuild and/or have a line on OEM turbocharger stock? Thanks in advance.
Off topic... How many miles on your car??
Old 11-03-2015, 11:02 PM
TNR911
TNR911's Avatar
49k
Old 11-03-2015, 11:22 PM
shadow993
shadow993's Avatar
49k
Thx... Only 30k more miles to go.
Old 11-04-2015, 12:37 AM
Kevin
Kevin's Avatar
Did you have any actuator codes? Is your ECU tuned? Yes, I can repair these turbochargers.. Replacing the bearings and sealing rings is the easy part. Troubleshooting the "cause of failure" is the hard thing. It sucks to rebuild the center section only to have it fail again due to a sticking vane>> Doesn't stick when the turbo is cold.. It binds when it's 850 degrees C
Old 11-04-2015, 12:17 PM
alexb76
alexb76's Avatar
What's the OEM Turbocharger? Why can't it be ordered from OEM supplier?
Old 11-04-2015, 05:19 PM
therock88
therock88's Avatar
Borg Warner - VTG's
http://www.turbos.bwauto.com/products/vtg.aspx
BW Part Number: * 5304 988 0061
OEM Part Number: 997.123.013.74
Manufacturer: Porsche
Vehicle: 911 Turbo (997)
Engine: 997 Top
Power (kW/HP): 353/480
BW Part Number: * 5304 988 0060
OEM Part Number: 997.123.014.73
Engine: 997 Top
DC
Old 11-05-2015, 01:39 AM
elite1
elite1's Avatar
So, your good for another 50K with refurbishment? Are you stating that the VTG could bind or fuse at 850C?
Glad to see you can do this Kevin. Can you also provide an upgrade at the same time?
Old 11-05-2015, 02:35 AM
Kevin
Kevin's Avatar
It's easy troubleshooting a non VNT turbocharger failure.. Oil contamination, oil starvation, heat damage, foreign object damage (compressor or turbine side) and external conditions such as bypass valve failures and compressor wheel burst due to overspeeding the rotating assy.
Additionally, with this turbo failures occur if the actuator fail OR if the vanes stick.. If the vanes stick or warp the turbocharger is write off. The cost of replacement plus the damaged center section exceed the cost of a new turbo. These turbochargers are failing, the 993TT also have a high failure rate due to excessive oil (leaking and smoking)..
This turbocharger can be fixed successfully "IF" the turbine VNT vanes are working correctly, AND if the failure was limited to failed sealing rings. IF it sustained bearing damage, the center section is not worth fixing due to compressor wheel rub (most likely) and scoured metal damage to the turbine wheel shaft.
Old 11-05-2015, 02:43 AM
elite1
elite1's Avatar
Does this work? Or, Can this be rebuilt into a more efficient turbo? Maybe this is why a 63 is minimum for rebuild?
Old 11-06-2015, 08:03 PM
TNR911
TNR911's Avatar
What you describe is what I've experienced and my turbo is a write off. The vanes stuck and that was the end. What I've also found is that Porsche seems to have scooped up what stock there was of the 997.1 turbos and are now only offering rebuilt turbos at twice the price of what was being charged for the OEM turbos.
I've been lucky to find a Rennlister who had upgraded his turbos and sold his originals to me at a reasonable cost. I'm anxiously awaiting the delivery. Thank you vr6tee.
Thank you to all on this thread for your help and advice.
Old 11-07-2015, 03:56 AM
alexb76
alexb76's Avatar
So, do you mean that no other parts supplier could get you a brand new Turbo at a reasonable price, but Porsche?
Old 11-07-2015, 07:03 AM
nzskater
nzskater's Avatar
What is the difference between the variations in the parts catalog? http://www.pepeautoparts.com/porsche...he/997123077ax
Quick Reply: Need 997.1 Turbocharger
