997.1 eyebrow light to LED swap?
I searched for awhile on the forum and even stopped at the local Porsche dealer but still not clear exactly which bulb(s) I need to swap my stock incandescents to LED (without throwing a code).
There are a few threads on Day Time Running (DRL) kits but I'm hesitant to go this route as I've read a number of people experience issues.
Rocky Mountain High
Which light do you mean, specifically? A pic might help.
This one....
It goes from white to yellow with the blinker/flashers. Not the "fog lights", I have LEDs in those already.
Hi there...
I think you are referring to the bulbs at the tip of the blinker blades? If so the are T10 Wedge bulbs. If you want to replace with LED...Simply get T10 LED that say CANBUS - No error. These have a small IC/Chip that reports that the current/resistance is proper to your DME so you do not get a CEL.
I have had them on mine for a while (I also have the complete DRL / LED blades)
Hope that helps.
DC
Here is an example of the bulb you need and on my car...not the best pics:
Hi there...
Hope that helps.
DC
Hope that helps.
DC
If I end up needing to replace them I will likely get the ones off fo efay for 1/2 that price as they look exactly the same...
Good luck,
DC
Oh - I have those too. They are Hoen branded but I got them from Maxspeed IIRC. Unfortunately both of them died (got very dim) in less than a year. They replaced one under warranty and I had to pay for the other. The new ones have been stable so far.
Simply search on eBay for "LED T10 Error Canbus" and ou will find tons of them. If you get a 50 pack for $5 from China...probably not going to last that long
Good luck,
DC
DC
Here is the difference on the HID's on my wife's Boxster S...I did the same thing here as on the Turbo:
Rocky Mountain High
I believe the factory HIDs are 4,300K, not 5,300K.
4,300K has been the industry standard for HID color temperature for some time.
OK, that makes sense. I just checked and I ordered 6000K T10s for the blinker lights and I guess I will give them a try as I don't remember what color temp bulbs I used for the "fog lights".
Actually I need to pull the front bumper to have the headlights buffed out because the Florida sun has taken a toll on them. Maybe that will be a good time to swap HID bulbs. DC, which brand did you use in your cars or does it not matter so much? Did all 2008 turbos come stock with HIDs? Sorry I am killing you guys with questions!
Here's a pic of the car. I really need to change my avatar. She looks fairly stock for now. I'm a relatively new owner and really appreciate the helpful advice I've received so far.
Rocky Mountain High
The car looks great! All 2008 turbos came from the factory with HIDs.
I've always thought it was silly that Porsche didn't make the front turn signals operate as DRLs from the factory.
On your headlights, they just pop out...Look in your owners manual...no need to remove bumper cover for that, or to change the end bulbs on the blinker blades...One Phillips screw and they twist out enough to change the bulbs....
DC
