997.1 "Custom Exhaust"
Before I purchased my car I was told that it had a "custom dealer installed" exhaust and a evolution tune from the prior owner. Service records from the dealer showed "R&R Exhaust and modify for straight flow". 9 hours labor.....
I was curious about this and asked the dealer that did the track inspection what was done to the exhaust and he said that he couldn't tell.
A couple months later when I replaced my exhaust tips I was surprised to see this....Is it a common mod??? Does it eliminate some back pressure? It seems like it would take 9 minutes and not 9 hours unless I am missing something.
Cheap hack job to join the primary and secondary chambers, minimal back flow reduction, just headache inducing.
The stock exhaust can be modified by replacing the cats and removing the clamshell, but that's pricey.
$1000 doesn't seem that cheap for what was done. I guess everything is relative. I haven't researched cats and exhaust systems yet but know they thy can get pricy. The car actually sounds pretty good to me but perhaps it's because I've gotten used to the low drone.
Would it make sense to start by replacing the cats? Are the stock ones very restrictive? Then perhaps replace the exhaust as step 2? Will the aftermarket high cats even bolt up to my stock exhaust?
The OEM is a big clunky thing too..You will usually save a little weight too with an aftermarket exhaust..
Good luck,
DC
Example of my Stock exhaust vs the Aftermarket ( Fabspeed Maxflo 3 and 200 Cell HJS Cats) I installed....of course no longer that shiny
You actually can do it in pieces. This is an fvd that I had on my old car. The stock 600cel cats are very restrictive, fvd replaces the cats with hjs 200cell cats among other mods. I can email a clip if you like.
C
C
Yes...I have seen that done, but that is a lot of work/cost to change cats and still have factory muffler(s) IMO...Then when he wants to do mufflers next....He has to cut them apart again?
I guess technically I mis-spoke as it can be done...My point was that it is one piece, so to be correct, you cannot do it in pieces without cutting the single unit in to pieces. Thus the photo...
Good clarification.
DC
Good clarification.
DC
When they (fvd) modify the muffler, they extensively modify it internally as well, removing the clamshell and enlarging the 4 crossover pipes. So, in theory, one wouldn't need another muffler. Downside is that its only 15-20% louder than stock. I've done both routes and in the end, one is better off just buying an aftermarket system when you're ready.
Very interesting...I may go the new exhaust route but repairing the convertible top mechanism recently cost me dearly so I'll wait a bit and in the meantime see if I can hear a few aftermarket systems from local PCA members and read more on the forum.
The Fabspeed Maxpro system did capture my interest as I see that it is offered in "Mild and Sport" sound levels. Under Mild they list carbio/auto and Sport coupe/manual...Hmmm, I have a manual cabrio with a Evolution tune. Waiting for the results from Evolution MS of exactly which tune is registered with my VIN.
Marauder1
Since your in Tampa I can tell you there are just a one or two places in the By area that do that Mod.
Typically they say a minor Tune is included. I have heard that Mod it's OK.
Ian
Ian
