Help, car still down on power...
Yes, it's been to P3 and I have no complaints or doubts that there's no longer a boost leak, but it's still down on power by about 1.5 sec in the quarter mile, and rpms still fluctuate +/- 300 until the engine is warm. I feel bad that I've brought it in 3 times for this issue and don't want to be that PITA customer. If you just drove the car you'd never know, but I keep such good records with my timeslips that I can definitely tell when it's not running 100%. The reason I mention taking it to Wright Motorsport is because they installed the tune and I've been talking with the folks at GIAC and am wondering if it was a software thing. My durametric arrives today, hopefully with the pentalobe socket so I can see if the MAF is the cause. If not, I give up.
Is there an easy way to check this? I have durametric data and it appears like boost is definitely down, although I admit I'm not exactly sure what all the numbers are/should be telling me. Reading posts furiously trying to get spun up.
CEL functionality is not disabled, although I do have the cel from the rear O2 censors disabled.
I haven't had a compression test done and hope it's not anything related to that. I really think it's a sensor/programming issue because the car will make tons of full power, just not consistently, especially during launch. From 1/8 to 1/4 mile, it's pulling the same as always gaining approx. 26 mph, but that first 1/8th is slow, on launch, at 60', 1000', etc.
Thanks for sharing the document, I'm sure helpful to many
OP, that sucks and is weird, keep us in the loop if you find out what it is. Since you basically checked everything I'm a bit at a loss here. Good luck.
Thanks for posting, this sounds exactly like what my car is doing, and my VIN falls within the range of this issue. I'll keep this thread updated on what I find. Cheers!
Remember to check the y-pipe connection near the throttle body also.
I recently had an aftermarket "worm clamp" clamping the Y pipe to the intake come loose during my last track event. Boxsters were flying past me while I was at 100% throttle. My car was also running rough at idle. I can only say that the car ran rough at idle while the engine was hot, I found the issue within 10 mins. reclamped the pipe and, idle was perfect.
Do you have any logs since you have durametric?
