Help, car still down on power...
(prob solved) Help, car still down on power
This is getting to be an old topic but I'm going crazy trying to figure out why my car is running so slow. Here's the pertinent info:
- car ran great earlier this year and I've made no changes since.
- just got the car back from getting checked for boost leak and it's tight as a button at 22 psi.
- Tires are not spinning at launch.
- during launch, it looks like the overboost function is not spooling as high as it used to--not sure if this is a cause or a result.
- idle at cold start up fluctuates for about 2-3 minutes between 700-1000. Once engine is warm it's rock steady at 800. I'm thinking this could be a maf issue, but once the engine is warm would it really cause that much of a power loss?
- power loss is around 1.5 secs in the quarter mile, significant for the upgrades and tune I'm running.
Any ideas from you guys would be greatly appreciated. Thanks!
When was the last time the plugs were changed? You also may want to check the coils as well. You are also right to check the MAF. Also what octane are you running? Race gas?
Hope this gets you started.
Jay
Jay
Plugs and coils were all changed last summer when I had the coolant leak fixed. I'm running 93 octane, same as earlier in the year when I was running 11.0 flat. Now I'm barely running 12.4's.
Can you log a run? Is your timing retarded?
Clutch slippage? Logs would be great to see if you have them! It sounds like you are chasing the same ghost I was last year. I don't really want to ask this but,
-How many miles are on your car?
-What oil viscosity are you running?
-Earlier in the season, you ran better but, do you think ambient air temps / Humidity may reflect on this change?
- what air filter is installed?
Maybe your racing adrenalin is fading with comfort?
(Avatar) Have you tried racing on Saturday night? Just kidding!
Despite the air not being horribly hot it's been really crap air for making power with all of the humidity lately.
Doesn't explain THAT much performance loss though. Wish I had better ideas... the obvious stuff has already been mentioned.
Still waiting for my pentalobe set in the mail so I can clean the MAF sensors. I'll report back if it makes a difference. If not it's back to Wright Motorsport to troubleshoot the problem.
This the car that was at P3 autokrafte? If so I know when I looked at the car I did a smoke test and found a vacation line off the FPR, which was checked and looked fine. So it was reinstalled with a ziptie (T&b) and I found a loose boost hose at the IPD plenum. I fixed that but suggested factory clamps as the wider aftermarket clamps used didn't fit as nicely. I did check it to 22psi at that point. I got busy with another car when the clamps showed up and a different tech did the replacement. However, he is completely competent so I doubt anything went wrong with that small change. You still having problems?
I haven't had a compression test done and hope it's not anything related to that. I really think it's a sensor/programming issue because the car will make tons of full power, just not consistently, especially during launch. From 1/8 to 1/4 mile, it's pulling the same as always gaining approx. 26 mph, but that first 1/8th is slow, on launch, at 60', 1000', etc.
