997 Turbo Forum 2005-2012
Any negatives to lowering springs?
Old 04-28-2015, 02:53 PM
  #31
jazz997tt
jazz997tt's Avatar
So no one has a response to my PSS10 question above? I'm not looking to just do springs as I've done that before on other platforms and its never been nearly as good as a set of coils with properly matched dampers and springs.
Old 04-28-2015, 08:25 PM
  #32
cgfen
cgfen's Avatar
Originally Posted by jazz997tt
For those with the Bilstein PSS10 and pasm, can you adjust both lowering and dampening or just lower the car? Also if you can adjust both can they be set in full soft to come close to oem normal setting?
I want the Bilsteins but don't want a harsher ride than oem pasm setup as its a daily.
i have P10's on my 993
They are ride height adjustable
They are single adjustable for both bounce and rebound.
At full soft they are still a bit harsher than stock suspension bits IMO
but
have not been a ride comfort issue
You cannot have P10s AND PASM
You can have their Damptronic coilovers AND PASM
Old 04-29-2015, 10:03 AM
  #33
Ray S
Ironman 140.6
Ray S's Avatar
Anyone else can answer this question please? Anyone that has had them swapped in and can provide feedback? Is KW V3 a better option?
I have no experience with the KW V3 on the 997 Turbo, but I have read about some bad outcomes with them on this forum and 6speed. You should be able to find them with a search.
Old 08-31-2018, 02:44 AM
  #34
pfbz
pfbz's Avatar
Received 2,721 Likes on 1,463 Posts
Quick Reply: Any negatives to lowering springs?
