Any negatives to lowering springs?
US and European versions have different ride heights from factory, the Euro being lower. I am sure the springs used in both are different, and the shocks used also would differ in their settings to accomodate a balance of firmness and plush ride on both. In my humble opinion, to achieve the lower height with springs alone, amounts to cutting corners. I wouldn't mind Springs on a regular Carrera for looks, but this is the mighty 480HP Turbo we are talking about, an expensive and highly balanced piece of machinery. Last thing you want is to hit some bumps under heavy braking (sebring?) before a 90 degree curve only to find out you are out of suspension travel (zero dampening), bounce off and lose traction. With as many DE's scheduled as the OP has, I'd put Coilovers, alignment and a corner balance.
Thanks for all the advise so far!
Interesting opinions about the geometry, this is what I was concerned about. I would love to see some objective (e.g. lap times, max g's in cornering etc) to support or refute this.
Though looks are important, for me track performance is the number one thing I don't want to mess up. I think I'll start shopping for some coil overs.......
To put my build into perspective, and this may sound really stupid but, I spent near 20K on my suspension and haven't converted to coil overs "yet."
I wanted to focus on Chamber and Toe. I needed the necessary adjustments to save my fricken tires at the track. May do the JRZ's of KW's next.
Given your situation, I would do the coil overs then.
Sorry, mistake on my behalf. I also installed a Cup shifter, Cup cables and new RS 4.0 clutch put in. I am near $17K for my suspension setup. I am running rear 997 rear Cup arms up the Front and 997 RSR arms in the Rear. H&R lowering springs, GT2 sways, 997 drop links (tarret) with Monoball's / labor and alignment etc..
Very cool object btw!
I'm in the middle of installing GMG springs but need to get a shock bump stop at the dealership tomorrow. I've heard good things based on what it is. But if you have the extra funds to burn, coil overs will have more adjustability. I don't so this is would be my first phase. I do all the work on all my cars so I have the flexibility of doing coil overs when the time comes.
For those with the Bilstein PSS10 and pasm, can you adjust both lowering and dampening or just lower the car? Also if you can adjust both can they be set in full soft to come close to oem normal setting?
I want the Bilsteins but don't want a harsher ride than oem pasm setup as its a daily.
I did GMG springs and sways at the same time. I love everything about it, the ride, the look and the the feel on the track. I'm sure coil overs would be better, but for 3-4 track days a year, I'm happy with my setup. Good luck with either route
I have H&R lowering springs.... the ride is actually nice. Approach angles are a little harder, but overall it works and looks better.
I am noticing a little squeakiness in the suspension when going over speed bumps and not sure what it is, though very minimal.
Bare in mind you are trading off suspension travel....
