GMG Racing Special Group Buy: CSF Aluminum Radiator for Porsche 997
Basic Sponsor
CSF All Aluminum Race Radiator for Porsche 996 997 Carerra GT2 GT3 and Turbo Models
GMG Racing Special Group Buy Ending June 1st 2015
Limited Quantities Available
1 by GMG Racing, on Flickr
2 by GMG Racing, on Flickr
In collaboration with CSF, GMG Racing is excited to introduce their line of All Aluminum Race Radiators for the Porsche 996 & 997 Carrera, GT2, GT3, and Turbo models. Each CSF Radiator is crafted from aluminum, and features upgraded surface area and stronger cross tubes for improved efficiency and cooling.
Aluminum Endtanks and Mounting Points
3 by GMG Racing, on Flickr
4 by GMG Racing, on Flickr
The CSF All Aluminum Race Radiator features aluminum endtanks and mounting points versus the weak plastic ones of the OEM units. The stock plastic endtanks start to degrade and become brittle over about 5-7 years time and tend to crack under high stress or vibration. CSF's all-aluminum endtank design are more durable and will last the lifetime of the vehicle.
5 by GMG Racing, on Flickr
The mounting points are all CNC machined aluminum as well versus the stock plastic mounting points. These are the parts of the tanks that tend to break off the most, especially during racing. When cars have bumper contact, or during high vibrations (i.e veering off track, going over bumps/ track chicane, high speeds, etc), the plastic mounting points tend to crack or break off, and the radiator starts to immediately leak fluid.
2 Row Core (dual core) with B-Tube Technology
6 by GMG Racing, on Flickr
The CSF All Aluminum Race Radiator utilizes a 2 row core (dual core) with B-Tube technology rather than the single row of the stock unit. The B-tube technology is exclusive to CSF in the N. American high performance aftermarket. The B structure of the tube is stronger than a normal "oval" welded type tube. Because of the structure, lighter and thinner aluminum can be used for better heat transfer. This also makes the unit extremely lightweig.ht, weighs just as much as the OEM unit. Also the seam down the middle creates more surface area contact with the coolant for a total heat transfer benefit versus stock of about 20%, and it will keep even the most powerful and demanding engines cool even if pushed in extreme temperatures and conditions.
CSF designed these radiators to “drop in fit”, requiring no modifications to OEM mounting brackets and stock radiator location.
Features:
- Mirror Polished Finish
- Precision ‘SAE Standard’ Filler Neck (Standard Caps Available)
- Drop-In Fitment Requiring No Modifications
- OE Specific Mounting Location
- Pressure Tested at 50% Higher Pressure Than OE Units
- 40% Higher Burst Strength Over OE Units
- All Aluminum Drain Plugs
- High Performance Multi-Louvered Fins
- Innovative ‘B-Tube’ Technology
About CSF
7 by GMG Racing, on Flickr
8 by GMG Racing, on Flickr
9 by GMG Racing, on Flickr
During the last 40 years, CSF has manufactured over 10,000 different models of radiators, oil coolers, heat exchangers, and condensers for automotive, truck, and industrial applications. CSF provides the best valued radiators and condensers that are designed to meet or exceed original equipment (OE) engineering specifications.
All CSF radiators undergo a rigorous testing process in their state-of-the-art testing lab. CSF’s procedures and requirements set the bar for cooling system relia
10 by GMG Racing, on Flickr
Tests Performed:
Individually leak tested
Vibration cycle tested
Thermal cycle tested
Wind tunnel tested for optimal radiator core cooling efficiency
Burst pressure and impulse cycle tested 10,000 times for strength
Salt spray tested for corrosion protection
10 foot "box drop" test to ensure packaging protection
30 point fitment inspection on critical dimensions to ensure OE fitment with no modifications necessary
For all inquiries, or to place an order, please email Ryan@GMGRacing.com
Features:
About CSF
Tests Performed:
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
