CAN pdk over rev?
Rocky Mountain High
I've heard that a dealer will CPO a car with range 4 over revs if a leak down test is performed.
There is no way to OverRev it under any driving conditions.
Ian
Ian
Now I have driven a number of manual equipped cars on steep hills that even in a gear lower than top (4th in a 5-speed and 5th in a 6-speed) vehicle speed can increase even though my foot is off the gas pedal. Engine braking in the higher gears is not sufficient to keep the car's speed from increasing. While engine braking is more effective in lower gears if the grade is steep enough and one took the engine to red line on the grade...
I would always have the over revs counters read just to be sure. And you can see how many 1 and 2 (possibly) over revs the engine has had and when and you also get the engine run time.
Thx. Just done know why often there appears to be some resistance from some dealers to get the overev DMe report. I'm guessing many sales people do not completely understand how to interpret them.
Even if the wheel becomes airborne and you never lift the throttle the engine will not Over Rev been there and have done that.
The Rev limiter cuts in the PDK and Tip have had this feature for a very long time.
Ian
Ian
