CAN pdk over rev?
Thats just the Rev Limiter cutting in.
Why don't you have the dealer pull a DME report and look it over.
In Theory an Engine internal Mass at 7300 RPM will unload when Fuel is Cut the Only way I can conceive of this not happening would be a steep down hill grade.
Ian
Ian
Also, the over rev reading requires use of the PIWIS computer and these are in short supply. Due to the high initial cost and high monthly costs dealers generally only have one of these and it is in almost constant use for new car sales prepping and warranty work, etc. Even my lowly 2002 Boxster which I dropped off the other day to have an airbag warning light on looked into required some PIWIS diagnostic computer time to read the airbag codes.
So, any time the dealer ship can get away with *not* using the diagnostic computer it is going to try.
Frankly, though, when it comes time to buy a used car I want the full read out regardless of the transmission type in the car.
The resistance I think comes from the fact the Tip/PDK is while not impossible to over rev difficult to over rev. It is not at risk from over reving like manual transmission equipped cars. Thus the DME over rev reading is seen as an added (and unnecessary) selling expense.
