IPD Plenum leak, need help...
Hi all, I finally located the source of my boost leak (see video below). While spraying soapy water with 12 psi going through the system, you can see a bit of a leak from the $750 EVOMS leakproof fitting (I'm not happy about that). However, there's a MUCH bigger leak from behind the IPD plenum where it's blowing air out as fast as it's going in. I'm not sure if it's blowing air from where the fittings connect to the plenum or where the hoses connect to the fittings. Are the fittings fixable? Any other advice?
Can't tell a ton from the video, but is there a drawing you can point to? (PET for instance)
I know several folks have complained about the IPD plenum, but I'm not sure what led to the complaint.
The only thing in the video worth looking at is the leak-proof clamp from EVOMS. For $750 I wouldn't have expected it to leak. The other point of the video is so you could hear the air rushing out the back of the plenum. All the air is coming out from the little tubes on the backside. I'm still not sure yet if the plenum itself is to blame or the hoses and connections going to the plenum. I'm not ready to go back to stock until I get the plenum installed without leaks and have a chance to time my car on the track with it installed. I keep good records of my timed runs and want quantitative data one way or the other as to whether the plenum is worth keeping. All the butt-dyno impressions don't mean anything to me.
Try and use a mirror to see if you blew a hose off the plenum. I blew the big hose on the right side (looking at it) on the first run. It is also real easy to have one of the side hoses fold at the bottom. Really hard to tell without getting in there with a mirror. I doubt one of the fittings are leaking because they epoxy them in pretty good. If it did blow a hose off just pre set a small zip tie and slip it on the hose. Then use some long needle nose pliers to pull it tight.
Cheers
Cheers
Cheers
Cheers
It has a slight barb on the end of the fitting and should have a crush style clamp on it from ipd. Yes it has boost all the time when spooling. Did you buy it new or used? I got mine used and didn't even come with the check valve so make sure that's there. It will boost your oil tank otherwise. I had to get one from Ipd. Really cool guys if you decide to call them. The zip ties will hold it no problem if you get it tight. The easiest way to do it is to loosen the motor mount nuts with a floor jack under the engine. Then just drop it down an inch or so, then you can access it pretty easy. Its a knuckle buster but not hard at all. Hope this helps. Any other questions feel free to ask.
Cheers
Cheers
We have had issues with the tapered brass fittings on IPD plenums leaking, so we like to seal everything with epoxy when performing in-house installs. If you're sorted on the check valve, the leaks may be coming from the fittings which would require some work to tighten or seal.
Sam
Yes, I'm a researcher and we have a lots of labs that use SF6 (I don't). Are you suggestig to run SF6 through the system and then try and pinpoint where it's coming out? I haven't worked with it but am assuming this is how it would be used?
Shoot me an email at sstone@evoms.com or call 480-317-9911 and ask to speak with Sam and I would be happy to ship out a whole new set of o-rings. Sam
Watch for the smoke.
Just like OP does, put the system on pressure and add SF6 with it.
