New Brakes and Rotors
I'm semi-new here, so I apologize if this has been discussed numerous times.
I've been doing some research on new pads and rotors for my TT. Is it better to just go with genuine OEM Porsche brake pads and rotor rather than another type. I know the TT stock brakes are very capable, but are others better AND cheaper? Just curious if there are other options.
i have the hawks ceramic pads on the rear and they are little squeaky but the dust is minimal. now only if they would make the front pads so i can have a matching set
stock rotors are high... i wouldn't replace the sensors unless they were damaged. i don't see the point of replacing the caliper bolt either since it isn't torqued to yield. pads and rotors is $1200 without sensors and hardware.
Sensor prices went up. They are now $35 a piece or $20 through Amazon. I got the Amazon one that a member here recommended and it wasn't long enough. I chipped the original sensor by trying to pry it out instead of yanking it. I pushed it back in and no problems after 1000 miles.
Definitely not $550 in parts for all four unless your using refurb rotors. Pads are almost $300 and rotors are $850 from sun coast. Add caliper bolts at $6 and sensors at $140. It must have been a while since you've done a brake job.
Definitely buy rotor screws for .40. They get butchered even if you use an impact screw driver.
Curious, how many of us actually change the brakes only after seeing a warning from the indicator? I suspect none or few. Most of us are always looking for something to work on and are always inspecting everything. There may be a few that wait for an idiot light to go off before checking....But based on the posts here I don't think many do
Anyway...everyone should do what makes them feel most comfortable....
DC
reviving this thread. Just started getting some squeaking from the brakes. Don't squeak all the time but occasionally. 10k miles ago the brakes were at 9mm front and 7mm rear. I'm no brake expert but I took a look at them yesterday and the rears appeared to be low. (correct me if wrong, see photos).
Heard Sunset Porsche in Oregon has the best prices. Assume I need to do rotors and pads.
Anywhere I can get a list of tools/parts needed for a brake job? Plan on doing this one myself.
Thx
FRONT
REAR
Thx
FRONT
REAR
i just replaced rear rotors, pads, etc on my 07 997.1TT as there was not much pad left & rotors had quite a lip- used stock parts- street only- front pads still looked good- bought car few yrs ago with 19k miles- now only has <30k- - Easy job - found write up somewhere here or 6sp-
to rebed, go out late at night.
Get up to 60 and brake moderately from 60 to 5mph.
Without coming to a stop, get back up to 60 and repeat about 5 times.
do 5 more times but braking hard.
Then, do 2 or 3 more hard stops from about 80mph down to 5 mph.
You're essentially just redepositing brake pad material on the rotors.
Once this is done the brakes should smell a bit. Bring it straight home and let it cool overnight
also, fwiw:
Front rotors:
99735140501 and 99735140601. About $462 for the set
Front Pads:
99735194701 $181
Rear Rotors:
99735240502 and 99735240602, $344 for the set
Rear Pads:
99735294901 About $170
About $1,155 in total. Parts are for standard not PCCBs and prices are from Sonnen in Cali.
Front rotors:
Front Pads:
99735194701 $181
Rear Rotors:
Rear Pads:
also, fwiw:
Front rotors:
Front Pads:
99735194701 $181
Rear Rotors:
Rear Pads:
Front rotors:
Front Pads:
99735194701 $181
Rear Rotors:
Rear Pads:
