Price check.
Thanks!!, I like white but I was thinking of choosing a different color, last 3 have been white....
This spec looks good to me, including the PCCB's. When I was looking at 09 997.1's I was somewhat indifferent to PCCB's. When I found a car that had them and now having spent some time in the car, I am blown away by how good they are in every respect. Unless you track your car on a regular basis why wouldn't you want them? On street driven cars the pads seem to last forever, my car with now 29,000 miles still has over half the pad life left. I do plan to change the pads early. I've been told that the key to long disc life (the costly component in the system) is to change the pads early. I think Porsche says to change the pads when they're down to 3 MM left. I plan to change mine at 4-5 mm. As the pads get thin they lose their heat dissipating properties causing excessive disc wear, something you want to avoid. I've been led to believe that with proper care the discs should last for over 100,000 miles.
