GMG Porshce 997.1 & 997.2 Turbo Lowering Springs and Sway Bar Kit NOW Taking Order
Basic Sponsor
GMG Racing Porshce 997.1 & 997.2 Turbo Lowering Springs and Sway Bar Kit
The GMG WC lowering springs improves the vehicle's performance, handling, and appearance.
The kit features an increased spring rate and drops the vehicle by 1" to lower the center of gravity of the vehicle to improve handling - reducing squat during acceleration, body roll in
corners, and excessive nose-dive under braking - and to reduce fender gap to give your vehicle a lower, more aggressive stance.
The GMG WC lowering springs utilizes a proprietary progressive spring design to maintain excellent ride quality. The progressive rate design uses a softer initial spring rate for excellent
ride quality and stiffer final rate for high performane handling. The spring rate increases when under load during cornering, braking, or load carrying etc.
Crafted from a high quality steel, the springs will not set or sag over time. The GMG WC lowering springs is designed and manufactured by Eibach exclusively for GMG. Through the
partnership, we developed lowering spring kits for high performance street applications using the data and knowledge gained over the years from professional racing in the ALMS and Pirelli
World Challenge series.
The GMG WC lowering spring bar kit is sold as a complete set and designed to use the factory PASM dampers. The spring rates are proprietary to GMG and they are specifically matched to the
factory dampers so that the vehicle won't be over-sprung and under-dampened or vice versa.
As an great alternative to much more expensive and more complicated coilover systems, the GMG lowering spring kit is an excellent set up for enthusiasts who would like to lower their car
and improve handling without compromising comfort.
• Drops the vehicle by 1" to lower the center of gravity of the vehicle
• Improves handling - reducing squat during acceleration, body roll in corners, and excessive nose-dive under braking
• Reduce fender gap to give your vehicle a lower, more aggressive stance
• Progressive spring design for excellent ride quality
• Smooth softer initial spring rate for excellent ride quality and stiffer final rate for high performane handling
• Manufactured by Eibach to proprietary GMG specifications
• Made of the highest quality and strength high tensile steel tubing to ensure consistent spring rates and no sagging
To further improve the handling of your Porsche 997 Turbo, we recommend our GMG WC Sport Sway bar kit which is 3 way adjustable front and rear and fully compatible with stock drop links
and have no issues with front axle interference.
The GMG WC adjustable sway bar upgrade kit for the Porsche 997 Turbo helps reduce body roll during fast cornering and to fine-tune the handling balance.
The World Challenge anti-roll bar features front and rear hollow tube anti-roll bars that are 3 way front and 3 way rear adjustable. The rear bar offers an increase in stiffness from 30 to
60% over the stock bar and the front bar offers an increase of 15 to 30% percent increase over the stock front bar. Complimented by urethane bushings to increase responsiveness, these
bars are a must have for anyone who is tracking their Porsche 997 Turbo or simply wants to improve the handing during spirited driving on the streets.
The World Challenge anti-roll-bar is designed and manufactured by Eibach exclusively for GMG. Through the partnership, we developed anti-roll bar kit for a high performance street
application using the data and knowledge gained over the years from professional racing in the ALMS and SCCA World Challenge series. The result is the improvement in the handling of your
vehicle without costing thousands of dollars like the bladed racing versions that we run on our race cars.
The GMG WC anti-roll bar kit is sold as a complete kit and is a true bolt on upgrade that requires no modifications to your vehicle and works with the standard sway bar drop links and
dampers or any aftermarket damper such as Moton, JRZ or Ohlins.
• Improves Handling and Reduces Body-Roll
• Stiffness in the rear bar is increaderd from 30 to 60% over the stock bar and the front bar offers an increase of 15 to 30% percent
• Perfectly Balanced for Optimum Neutral-Steering Handling and Precise Turn-In Response
• Precision Hi-Tensile Steel Alloy, Cold-Formed, Tempered and Shot-Peened for Long-Lasting Performance and Durability
• Precision Forged Ends and OEM Style Pressed Bushing Locaters (No Welding Or Weak Points Here)
• Greasable Urethane Bushings For Increased Responsiveness
To place an order, or for all questions and inquiries, please email Jerry@GMGRacing.com
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
Can you tell me what the springs rates are (F & R) for your springs please?
One of my pet peeves is vendors on forums who pimp their products but rarely respond to the threads.
Basic Sponsor
I apologize to yourself and any forum member that does not receive a response on our forum threads. I do not always get an email notification. For a prompt response, I can be easily reached at my email address listed
Basic Sponsor
Our spring rates are variable as they are a progressive as opposed to linear. The springs themselves are matched to the OEM dampers and exact details about them are proprietary but here is some feedback that we received from a shop that installed our springs for a customer:
“Recently I worked on a 997.1TT with same exact suspension components from GMG. Once the engine repairs were done, I took the car for a final road test and data logging. During the test drive I was absolutely impressed with the suspension set up. Having installed every off-the-shelf lowering springs as well as coilover kits, I find GMG springs SPOT ON. Very easy comparison to H&R springs, the GMG springs do not display "typical" lowering spring draw backs. There were no bouncing or bottoming out. The car felt very composed and planted. The car is not too low, but with just enough drop and a classy stance. There were no bump steer or toe steer symptoms, and the ride was comfortable. Since that day, having one on one experience with the suspension set up from GMG, I am recommending this combo to my customers who are seeking to tighten the suspension but not wanting to spend too much money. Good work guys!”
-Berk, DBC Tuning.
If anyone have any further questions or would like to place an order, please email me directly at Jerry@GMGRacing.com for a prompt response.
Basic Sponsor
