991.2 multifunction works in a 997.1
I have a 991.2 in my 997.1 and could not figure out the multifunction. This genius did, and sells the upgrade.
Facebook Post
Have you tried it? The dash in his video looks like it's more modern than a 997.1
I'm confirming things up. I did not have a multifunction wheel. I added the 991.2 wheel and a new module. I will let you know if it has to be programmed for multifunction with a piwis.
He said no programming needed, but he's in China, so I confirming. I don't want anything lost in translation. More to come.
if you have non-multifuciton 997.1 wheel you will still need the 997.2 steering wheel module first (then programmed with PIWIS to turn multifunction on)... the lim-bus adapter will then translate the protocols to get the multifucinotn steering controls to actually work.
Hi Guys, fitted the adapter today, it was really quick and easy. No programming necessary, as I was already set for mutifunction. Works flawlessly, real plug and play.
My Turbo is a 2007 with PCM3 retrofit.
One of the best and most simple mods, that works out the box (Like DSC) that I've yet done.
C
Hi Guys, fitted the adapter today, it was really quick and easy. No programming necessary, as I was already set for mutifunction. Works flawlessly, real plug and play. My Turbo is a 2007 with PCM3 retrofit. One of the best and most simple mods, that works out the box (Like DSC) that I've yet done.
Originally Posted by TT Surgeon
Cool, how'd you do the pcm3 retrofit?
C
C
