997 TT Tyre (Tire) Noise
Ladies and gentlemen. I have a 997.1 TT which I use as a daily driver and for "spirited" country touring in Australia. I've had it for a 18 months and have had various tyres on it. The tyre roar is quite intrusive at speed (as it was on a 997S I had some years ago) and is much worse than on a 996 C2 I had in the the early noughties (I also have a 2000 996.1 GT3 for club sports use and it's so noisy I can't even hear the tyres!).
Has anyone out there had a go at a fix for this issue (the new 991 appears to has solved the problem)? By his I mean spaying under guard treatment on or applying some other sound deadening inside the wheel arches. My experience is that tyre choice has only very marginal effect and it's a basic design/construction issue.
Warwick
Warwick
Yes the tyre roar on course bitumen is bad. On smooth bitumen it is ok but thats about it. I think doing long trips would be a bit tiresome and frankly there are better cars to use for those applications. I recall a member over on 6speedonline under the user name car narcissist (or something like that) who posted a thread on how he dealt with the issue using sound deadening material on the inside of the car. It required all the trim to be stripped out so was not an easy job but he did report later that it was a worthwhile exercise for what he wanted. Maybe do a search over there and PM him. Cheers.
Thanks. I won't be stripping the interior. It's mainly a city driver with occasional fast country road work. Will have to stay with noise-cancelling ear buds and Spotify on the phone for the longer trips.
You might think this is crazy but I know that Alfa Romeo fitted in the 156 the wheel arches a kind of carpet to dampen the wheel/road noise. It seemed to help.
But I would not want that on a 200 mph car.... What could go wrong when it comes under a wheel when breaking.
If you want to know more I can try to look it up for you.
See also other solution on classic Porsche http://www.lokari.nl/
Registered User
I always wondered if it would help if you could stick some dynamat on the backside of the plastic wheel well liners.
http://www.eastwood.com/dynamat-extreme-wedge-pack.html
Trucker
http://www.dynamat.com/
I have used it in bare metal resto-rod such as '55 Chevy with a 632 or a '32 3W Ford with a Flattie,..never in a sophisticated car such as a 997TT.
As ILKO said, worn tires tend to cause a lot more "ugly" tire noise...but if you really want "ugly" tire noise in a 997 the GT2 is really bad!!!
"Haaaaaaaaah? What did you say...."
Registered User
