997.1 with DFI TTS motor
If i were to buy an 08 997.1 TT roller shell , would i be able to purchase a used 997 TTs motor and drop it in ? or would the shell have to be 997.2 09+ ? thanks!
Agent Orange
The DFI motors were 2010 and later. I believe the transmission for those is also different. And you will need a complete re-wire, ECU swap, and other fun things to make it work.
I am planning on buying a car damaged from the front clip back just so i can use the drivetrain , so i will have every single drivetrain part that you just listed , so technically will this mount up to an 09 or even an 08 if i have it all? or are the mounting points different or something. The shop i asked told me it was impossible because tranny and edu plugs willl be different but i will have it all.
Trucker
You may also need to hire an electrical engineer with a PhD to support the project. The issues with these conversions is usually not the mechanicals and the fabrication but the little electrons running around in the multiplex wiring system.
Do a real business case on the project and plan on contingency $ as it can be expensive.
GL.
GL.
GL.
GL.
Agreed.. You are in for a nightmare and th cost will be prohibitive to say the least.
Even in 996 Carrera going form a 3.4 motor to a 3.6 was a nightmare (ask me how I know.)
Now you are talking about mating two different year models with completely different drivetrains and electronics.
You would be crazy to attempt this.. Just buy an 08 or and 2010 and be happy..
You have been warned..
So if i do the same with a 997 it should be the same , i assume maybe you guys mean if i try to put a dfi drivetain in an 08 and below i will have issues
this is for going for putting a DFI motor in an 08 and below right, if i have an 10+ shell then everything will bolt up where its supposed to go no modifications needed.
In fact, if you take a perfectly operational 2010 DFI turbo. completely strip it and then reassemble it you will likely end up with tons of headaches. Not worth it IMO unless you are saving $50K.
Heck just look at all the trouble folks are having after they improperly install a simple plenum, exhaust, tune or any other minor mod. Now imagine trying to trouble shot something in a car that has been completely reassembled. Makes me queazy just thinking about it LOL!!
I think what people are saying is that your assumption that if you have "everything" it will be a simple "plug and play" is overly simplified. Pulling everything apart from the donor car and reassembling everything into the new shell is a major job with a million electronic gremlins just waiting to give you a nightmare
At least you would get a some opinions form people that know exactly what you would be up against..
This is car that lights up the dashboard if a button isn't working or a turn signal is acting up. No way I would ever consider a project like this on one of these cars. I can't see how you would spend less than buying a 997.2. It would also have basically no resale value.
