997 Turbo Forum 2005-2012
Blower Fan Failure
Old 06-14-2021, 11:16 PM
tmshinro
tmshinro's Avatar
Well I finally was able to do some investigative work. I verified the fan works by putting 12v to it. I also verified that I did not blow any fuses. So I'm thinking relay(s).
Hans' post shows the high speed relay in position 8 and the low speed relay in position 7. I don't see any position numbers on my relay block. Can anybody tell where these are located on the relay panel? Do they have descriptions or colors on the case to identify them?
Old 09-03-2021, 02:25 PM
rhiar
rhiar's Avatar
Default What did u figure out?
I have the same issue. What did u find out?
Old 09-03-2021, 03:03 PM
964hans
964hans's Avatar
HI,
See link: https://rennlist.com/forums/996-turb...ler-relay.html
997 relay support is at the same location
Regards Hans
Backday (09-03-2021)
Old 09-03-2021, 08:01 PM
tmshinro
tmshinro's Avatar
Thought I'd inform everyone what my inoperable fan problem was. I had to get a new windshield installed so I took the car to a Porsche dealer. I asked them to look into why my fan had stopped working. After two hours of sleuthing they discovered that the shop that did my engine out service in the spring failed to plug in the connector to the rear relay panel, which powers the fan. Hasn't been hot enough to see the fan work but I assume all is well now.
Thanks to everyone the offered assistance in answering my questions when I was trying to figure it out.
Robocop305 (09-03-2021)
Quick Reply: Blower Fan Failure
