Sport Button vs Tune
Hello Guys,
Just discovered my sport button few months ago and I LUV IT.
I am now wondering how much more fun is a tune vs the sport button?
The difference between the stock setting and sport is very noticeable
and is it the same between the sport and the tune ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
C2..... Brother I'm saddened that you just discovered the sport button...
The sport button with a tune rocks..
The car behaves the same with a tune but with more power. The turbo's spool faster and you have a lot more torque.
When the sport button is engaged it advances the timing just like stock. So I guess the answer is the the sport button with a tune is awesome..
But a tune+exhaust is really all you need to unleash the beast in your car. It's more responsive, turbos spool earlier on the low end so you have more accessible power below 3K. and the turbos spool faster in general with a free flowing exhaust so you have much less turbo lag across the entire rev band. And in sports mode the turbos will maintain boost all the way to red line vs cutting of at 5K. Totally worth it IMO
GL
Art
edit
when I completed my PPI the service tech told me to get a tune because "it wakes up the car like you wouldn't believe".
With a tune the you will notice and even bigger change between the two settings. I actually prefer PASM stiff and sports mode off on the track, far too sensitive to throttle inputs.
How many people have tunes and a stock clutch? I have been told the stock clutch won't last long. I was told the same thing when I upgraded the turbos on my B5S4 but I never had a clutch issue.
Stock clutch here and in my old blue car, which dyno'd at 466 awhp, about 560 crank. Never slipped. I think 550-575 is about the limit if the stock unit. Just my experience, others can chime.
Plenty of threads on this topic, many good tunes each with good and bad feedback.
I have 65k miles on my stock clutch. 25k of those with the tune and exhaust. It is finally starting to slip in 4th and 5th with race gas at WOT.
Have to get that done soon. Possibly go to the 2.5 clutch or just another stock. Not sure yet..
It makes sense what TT says about max HP for the stock clutch.. Mine does not slip with pump gas. But it does with race gas (which may put it over the 575 hp mark)
