Source for Exhaust Fabrication Parts?
Due to my inability to stomach the Porsche tax, I'm seriously considering building my own exhaust system. It should be pretty straight forward but the only hangup is I'm not sure where to source the flange that bolts to the turbo. In the attached picture it is the flat plate right next to the O2 sensor bung. Anyone have any recommendations on where to find those flanges? Other than those, the rest of the system is comprised of off the shelf exhaust parts. $3800 for a system comprised of $500 in parts seems a little excessive to me. Thanks.
Is this the same K16? I'm not familiar with the KKK K16 turbo, but then again I'm not well versed in the stock turbo on the 997.1 TT. Is the turbo the same between the 996 and 997.1, or at least the discharge? Thanks.
http://www.034motorsport.com/fabrica...6-p-13895.html
It will be SS if i go ahead and build it. I sold my Lincoln 255, but I'm pretty sure I can find a welder to use. Ti would be my first choice, but that would be a PITA, and not worth the weight savings.
So, just a thought. I know Agency Shower makes a cat/muffler delete that is a straight pipe from the turbo to the tips. Obviously this would be hellaciously loud. I'm wondering if the noise/drone would be tolerable with a 6-10" muffler between the turbo and the tips instead of a straight pipe. Magnaflow makes a 6" long x 6" round muffler with 3" inlet/discharge. It appears to be the same muffler that Protomotive uses in their x-pipe system. I'm just wondering if ditching the x-pipe and going straight to the tip would be tolerable. I think I could fit as long as a 10" and maybe a 12" muffler between the turbo and the tips.
http://www.vividracing.com/catalog/2...-p-104419.html
This is the Magnaflow that I believe Protomotive uses.
http://www.magnaflow.com/02product/s...=main&id=11089
we can supply you with everything you need to build your own system - HJS cats with or without endcaps, O2 bungs, bends, straights, resonators, tips, turbine flanges, ect. - feel free to shoot me an email with your needs.
If you are gonna do your own custom Stainless exhaust system, then you can buy all the bits and pieces from Speedway Engineering and cut and weld your own system to your own desire. You can get ID up to 3":
http://www.speedwaymotors.com/
They are usually cheaper than anything from pcar suppliers (respectfully)...
For ALL my "other" brand cars (pro-touring/race cars) I have always bought here and fab'd including the headers...you can make some sexy looking low restriction stuff...
