DME Report Guidance - Thought's?
Hi All,
I am closing in on purchasing my first Porsche - an '07 997TT. The owner sent me this DME report. Based on my limited knowledge, I am hoping to find a car with no Type 3 + readings. That said, it seems there are few out there that have anything under Type 3 readings.
Thoughts on this report? Good or bad? Should I worry about pursuing this car further? It has 36K miles on the ODO and looks to be very clean. Has about a year left on the CPO warranty. That said, I would be bringing this car into Canada and my understanding is that the warranty is null and void.
that DME is fine, at 36k miles, and with that low of range 1 numbers, the car was babied. Almost too much
I just decided to pass on a car w/ 24k miles that was flashed and had the following:
Range 1: 20420
Range 2: 2756
Range 3: 779
Range 4: 211
Range 5: 0
Range 6: 0
Range 1: 20420
Range 2: 2756
Range 3: 779
Range 4: 211
Range 5: 0
Range 6: 0
OP I think the DME looks fine, good luck
I just purchased a 07 tt with the following. 10,151 miles. The range 1 is really high, didn't really notice that until now. I wonder if the car was flashed which would cause the high #1 readings? I'm not crazy about the fact that the car obviously had the worst missed downshift of its life 2.3 hours ago. But since it only had 2 ignitions in range 4 it couldn't have been there long. Fingers crossed that I don't have any issues. The car is flawless and was obviously babied.
Range 1: 6015 336.3h
Range 2: 340 336.3h
Range 3: 37 336.3h
Range 4: 2 336.3
Range 5: - -
Range 6: - -
Operating Hours: 338.6h
Range 2: 340 336.3h
Range 3: 37 336.3h
Range 4: 2 336.3
Range 5: - -
Range 6: - -
Come on people
This DME thing is getting way out of hand. This engine is not made of chocolate you know !
FAR more important than a few over revs is the fact if the engine was revved when cold. You can't measure or verify that.
Once people come on a Porsche forum they start reading about over revs and panic. Are you all just 18 or so ?
Didn't you buy (used) cars before ? Did you all worry about over revs than ?
MJK944, probably that 'driver' took great care in warming up the car before hammering it. So very likely that car would have given you great fun. Free revving, well broken in cars tend to have more power.
I am sure you'll find a 'clean' DME car soon, lets hope the owner did not forget to warm it up before stepping on the gas and changing gears at 5500 rpm.
Edit: wanted to add that Porsche CPO's cars with type 6 over revs when past 200 hours operating and after leak down test.
Registered User
Come on people
Are you selling your RS4? I recently bought a 997.2 turbo 6 speed and although I like the car, I am glad I kept the RS4 as the high revving v8 and exhaust sound is great to come back into after driving the turbo...don't get me wrong...turbo is fast and fun but the RS4 just has its own unique character. I am keeping both for now. Good luck in the hunt.
Come on people
Well said Denis!
Come on people
The DME overrev counters is just one bit of data to help a prospective buyer make a good decision about a used car. The buyer is free to assign any weight he wants to based on what the overrev counters have to say.
Many of us bought used cars before the day of overrev counters. But I wouldn't trade those days for these days. I like the fact there is a rev limiter and not only that but there are counters that are used to record the overrevs should they occur.
If one is buying a CPO car then over revs in the higher ranges may not matter so much. However, I note many a CPO warranty expires on time and not miles so it is not like Porsche is on the hook for the car a full in the case of my Turbo 100K miles. My Turbo's CPO warranty expired on time after I had managed to put just 50K miles on the car. Still I felt I got the benefit of a full new car warranty, and then another 10K miles. [Added: The car was bought used with around 10K miles on it.] Which points out Porsche was only on the hook for another 10K miles over the 50K miles warranty the car came with new. Thus while a car with overrevs in the higher ranges can be CPO'd, it is not a real strong recommendation to buy one as Porsche's exposure can be quite low. But if one is going to hang on to the car after the CPO warranty expires then the exposure once again is borne by the owner.
So, if one is buying a car sans any warranty he is entitled to be a bit more selective in which cars he considers, if he wants to be.
Last edited by Macster; 07-05-2013 at 06:45 PM. Reason: Changed hand to hang. Added [Added...].
DME aside, a US car under warranty is also under warranty in Canada. Porsche's Canadian dealers will try hard to make it sound difficult/impossible to import a car but even on their site they acknowledge that a US warranty is valid. http://halifax.porschedealer.com/canadian_owners/index4.php
Good luck!!
