Clutch bleeder valve, Dension and radiators
I did my first ever brake bleed this past weekend and it went without disaster (997.1 T)
However, for the life of me I couldn't find the clutch bleeder valve, so I skipped it.
I took off the rear underbody panel, looked at the PET, searched the forums but never found it.
Anyone here savvy enough to know where it is and if one even exists?
Notes on the brake bleed - I think this can be done without taking the turbo wheels off although I did. At the end the brake fluid was filled to the brim. To lower it, I filled up the motiv with air and pushed a bit more brake fluid through one of the calipers.
I did Dension 500BT install behind the head unit the prior weekend and used a bypass loop for the factory CD player. PITA. Feel free to get in touch if you are having trouble with this (dopple_64@hotmail.com) Oh and firmware updates where needed to get bt streaming to work.
Radiator cleaning the weekend prior. A lot of shiziole does indeed get caught up in there. I had a detailer come and pick the radiator clean!
