997 LED Tail Light Install Video - All Models - All Light Manufactures
Former Vendor
Here some photos and videos on a 997 turbo LED tail lights install and some tech tips
Before
![](http://i1104.photobucket.com/albums/h336/DRCinc/reggie%20997%20full%20led%20upgrade/IMG_0273_zps2e0455d7.jpg)
![](http://i1104.photobucket.com/albums/h336/DRCinc/reggie%20997%20full%20led%20upgrade/IMG_0274_zpsa28348a1.jpg)
After
![](http://i1104.photobucket.com/albums/h336/DRCinc/reggie%20997%20full%20led%20upgrade/IMG_0276_zps5192a538.jpg)
Before
After
![](http://i1104.photobucket.com/albums/h336/DRCinc/reggie%20997%20full%20led%20upgrade/IMG_0275_zps7113696a.jpg)
Former Vendor
Tail Light LED Turbo resistor install E.C.L warning light fix
WE ARE NOT RESPONSIBLE FOR ANY DAMAGE.
we always recommend professional install this is a walk through for the D.I.Y 'er.
Some led tail lights trigger an error code or warning light on your dash. LEDs do no have the same resistance as regular bulbs. Resistors in series will eliminate those issues so no warning check engine lights come on the dash. We use two resistors in series to reduce the amount of heat that they generate, make sure to tap onto the signal wires only. We always recommend soldering your connections but the the do it yourselfer, t-taps will work fine. Make sure they are tight and snug when plugging them in.
Former Vendor
Our Porsche 997.1 Upgraded tail Lights Side By Side Comparison LED Upgrade tail lights with OSRAM LEDs.
For More info Email Saturndrcmedia@gmail.com
or call 310-827-8121
http://www.ae-33.com
http://www.facebook.com/AEMarina33
http://www.twitter.com/delreycustoms
http://www.yelp.com/biz/al-and-eds-a...marina-del-rey
Powered by DRC Media LLC & Al & Eds Autosound
Former Vendor
So we just got the opportunity to do a full LED Lighting Upgrade for the Fine people over at Porscheof Fremont, a Fletcher Jones Dealership.
We just got done doing The full LED upgrade package (tails, bumper, sides) with the Auto DTR For modification so the White LED are on all the time auto with the Ignition
Here's Some Photos, FYI The car look to have the Vortec Supercharger in it.
Visit Porsche of Fremont Web Site Here!
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216662&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216663&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216664&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216665&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216666&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216667&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216668&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216670&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216671&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216672&dateline=1362089955)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=216673&dateline=1362089955)
Former Vendor
So Here's some stuff I hope will help
I done some work on a few cars yesterday and this is what I came up with...
If your using the red bulb you need 1 set of resistor juston the driver side and here is the photo. If you tape of the parking light prong inside the scoket, the car still see the parking light for the 2 other s****ets that share the same circuit. so the fix would need to be added to just the driver side. the pass side has no current on the grey/white i metered it.
![](http://i1104.photobucket.com/albums/h336/DRCinc/997%20auto%20mod%20DTR%20Installs/leddriversidemod_zpsc246057d.jpg)
Now if you want to run no bulb the should work as well
now If for no bulb or you want to go with red led/smd bulbs then there are 3 sets of resistor needed. to clear the code.
![](http://i1104.photobucket.com/albums/h336/DRCinc/997%20auto%20mod%20DTR%20Installs/ledresistorpass_zpsf6b2e3ca.jpg)
![](http://i1104.photobucket.com/albums/h336/DRCinc/997%20auto%20mod%20DTR%20Installs/ledfogdriver_zps7d5364a8.jpg)
I hope this helps may work on other manufactures as well.
Email me if you need extra resistors. If your not using them on the turn singal try just the driver.
simple kit 1 loop @15 shipped
deluxe 3 loop kit $45 shipped
Email me SaturnDRCmedia@gmail.com to order
Former Vendor
Question,
I have these lights installed in my 997.1. When I remove or tape the passenger side red bulb I lose the whole right side light (LED's go out).
Is there a solution for this?
Thanks in advance,
Joe
** I fixed my issue thanks to help of Shane. I had a plug incorrectly set. Thanks Shane.
Thanks in advance,
Joe
