997 turbo center lock wheels
It is probably too late for me to change my order, but why all the negativity about the center lock wheels? I know they are heavier but is there some other inherent down side? Dealer will have the necessary tools so why do I read the recurring theme of negative vibe about the center locks? I wanted a manual turbo S so adding ceramics and center locks plus the PTV was as close as I could get with a manual.
It's much harder to change wheels with the center locks and the mechanism should be maintained every time you change a wheel. If you don't track your car, then you probably don't change wheels very often and it would be nothing to worry about.
I will do an occassional driver ed event through PCA but no serious track time. Don't know about the rotational mass difference between the two wheels. Macster or TT surgeon might have an opinion; they seem to be knowledgeable.
The centerlock rims look awesome. What is the maintenance does anyone know? Is it harder than torqueing 20 lugs vs 4? The NEW turbo II rims look awesome too. You can't go wrong with either.
Single lug puts you on a F1 / nascar dimension. Thats purdy cool.
http://www.6speedonline.com/forums/9...ips-tools.html
The center lock wheels (and low profile tires) are a big issue for me. I am using my turbo s as a daily driver in the DC area. Hit potholes twice last year. Both times, the low profile tires blew, and once a rim was damaged. The car has had to be flatbedded to a dealer - no problem in the metro area. But took three days to get a replacement tire. I'm afraid to take the car on an excursion now, as any tire or wheel issue that can't be handled with the supplied tire repair kit, will end the trip and create a major hassle. I know this is not a concern for track users or neighborhood drivers. But a big concern for guys like me who use the car as everyday transportation, and modest trips.
I'm not a fan of the centerlocks and feel that they do not have any upside other than looking cool....and no doubt they do this well.
My feeling is that removing and replacing a wheel should be facile and with the centerlocks this is not the case.
As long as you get a 3/4" drive 4 foot torque wrench (you can get them for about $350) it isn't a big deal torqing the center locks to the 500nm (350ish ft/lbs) (or 600nm IIRC if tracking the car, I'd have to look at the tsb again to confirm the spec).
If the wheels have been installed for a few months, it will take someone pushing on the brake pedal while another person loosens the centerlocks. Otherwise you will just spin the tire on the ground. They can be mighty tight to take off. That alone makes the 5 lugs much easier to deal with (which in comparison torque to 96ft/lbs).
