Warranty Issues with Aftermarket Exhaust?
Noobie Here - In the process of acquiring a 08' TT Cab CPO, I plan to have the TUBI exhaust installed shortly after purchase. Has anyone experienced repairs to their TT that were declined to be covered under warranty due to the aftermarket exhaust? What about with a EVOMSit Software upgrade like the one below:
EVT S1 550 Includes:
-EVOMSit ECU Tuning
-EVOMS Boost Recirculation Valves (Pair)
Thanks in advance..
-EVOMSit ECU Tuning
Thanks in advance..
-EVOMSit ECU Tuning
Thanks in advance..
-EVOMSit ECU Tuning
Thanks in advance..
I just upgraded my ECU using Softronic. Because this is done through the OBDII port from my PC it is easy to get around warranty issues. The softronic folks sent both my original map and my tuned map. Whenever I go to the dealer I just replace maps so they only see the original. Because softronictuning is also including the Durametric cable I can also clear any faults. Dealer hasn't got a clue - warranty just fine. You may wish to consider upgrading your exhaust then use Softronic or something similar (that allows you to keep your old map) for the ECU upgrade.
Besides, what you're doing is fraud.
Sincerely,
Macster.
i've heard that the dealer/porsche can detect any mods to the ecu if they really want to know even though you download the original file prior to warranty related repairs. in regards to the exhaust, the dealers themselve advertise aftermarket exhaust upgrades so i would not think that the exhaust would void warranty repairs. i personally would not do anything to the ecu until your warranty expires..
My warranty expires in a couple of months, so I'm not so worried. I haven't needed any warranty work done on the car so no fraud committed. The old map will be useful when it comes time for emissions.
In terms of exhaust, the dealer has never had issues. They've asked I keep old exhaust if ever I intend to sell the car back to them, so they can put it back and offer car as Porsche certified. Not sure it matters that much as the car gets older.
The ST, and all obd2 port flashes are detectable, regardless of what the aftermarket companies claim. I have the fvd, which uses the ST flashloader program with the same cable, etc, trust me they were well aware of it when I had my car in there last, even 'back to stock' flash.
tt surgeon- I've enjoyed reading your posts just wanted to say THANK YOU!
How's life been with the FVD? I'm considering the upgrade. My tech is wonderful - works with ronda who I've heard only positive responses. I wanted to really settle into the TT coming from a C2. Done over 5k in 3 mo. what a blast, makes running from NOLA to houston nothin..
I'd like to do an exhaust as well. you have euro pipes or fvd? any clutch issues? my tech down the road said - yeah you may need to do it... we turn wrenches on the side. I sold a kit when I sold 911's for a 996 TT- FVD- what a monster - no issues - tech hasn't had any.
They can look and see the engine run time vs mileage etc to find irregularities -i've heard FVD can make a copy - update it if necessary. Although my dealer won't look bc well - its being done there.
My mod exhaust randomly sets off the secondary cat converter sensor indicating too much unburnt fuel, which is weird becasue the first in-line cat senson never picks it up. I don't know what's going on... I just keep restting the check engine light, whcih is a pain in the ***. Porsche dealer says warranty won't cover due to the mod.
PAG knows when the ECU has been 'flashed' ... trust me.
Your warranty coverage will be determined by PCNA, who will reimburse the dealer for warranty service.
It is at the discretion of the dealer to decide if the modifications done to a car are of sufficient scope to risk them "holding the bill' if PCNA decides to decline warranty coverage at some point.
If a car is up on a lift and a PCNA manager walks thru a dealer's service bay and sees a modified car, it might not be your lucky day.
But again, it all depends on your relationship with the dealer.
Question.
If a tt was flashed and car driven with "some" sanity
and not tracked what is risk of engine failure?
Do any of you know stories to share of engine failure
because of flash?
Just interested in anecdotal tales of woe.
because of flash?
