GT3 Wheels on an '09 Turbo
I would assume they are narrow body offsets so you'll need a spacer for the rear. Someone needs to chime in on the offsets. If they are sized like the 997.1 GT3 wheels the rears will be maybe 67mm while the turbo needs 51mm. I run 997.1 GT3RS wheels on my 997.1 turbo - the GT3RS wheels do have the widebody offsets.
Newbies Hospitality Director
Cowhorn,
That ^ is correct. The GT3 RS wheels would fit your car.
However, the 997.2 GT3 RS wheels are center lock wheels, and, as I recall, your Turbo does not have center lock wheels. If that is the case, then you would need to get the 997.1 GT3 RS wheels.
Jason (atomic80) installed 997.1 GT3 RS wheels on his Cobalt Blue 997.1 Turbo about 4 years ago. Here is a link to his thread which contains a couple of pics.
997.1 Turbo with GT3 RS Wheels
