Check Engine Fault
Check Engine Fault
Have a 2010 TT. Got a "check engine" light and brought it to the dealer. It is apparantly a problem with the exhaust in that the car things that there is a problem with the exhaust...but there isn't. There is a technical bulletin out therer but no fix for it. Anybody had the same issue that was fixed with success that I could tell my tech here?
Are you experiencing random power loss? If so then there is a known issue. Apparently there is a sensor that is only used in Japan markets and everywhere else leads the computer to assume incorrect exhaust temps. I had this issue on my 2010 TT. Apparently the fix is to disconnect the sensor and put a dummy plug on it. I havent had an issue with power loss or high exhaust temps since. I would recommend calling Peter in the service dept. at Pfaff. I deal with him and he is very familiar with this issue as we had been trying to find a solution for my power loss since May.
