High Rev at Startup - Anyone Experience This?
I recall others having this problem, but I can't seem to find the threads.
Has anyone else had intermittent high-revving startups when the engine is cold?
It happens occasionally on my 2007 Turbo (GIAC, AWE exhaust, nothing else)--just revs to about 2500 just at startup but comes back down to 1000 or so within a second'ish.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Only on my Lexus IS 350. Never on the TT.
There was a thread on this a while back, either here or one of the other forums. The consensus is that is does occur intermittently, some cars more often than others. Regardless of whether it is an issue with different cars, different software, different driving styles, or something else, the consensus was it is normal common and no big deal.
Last edited by sparkhill; 03-11-2010 at 01:48 AM. Reason: changed normal to common
It happed to me again last night warm start and this morning cold start.
InTheAir, this time I looked and the rpm was close to 3K before coming down.
It is annoying and not good on a cold engine.
Anyone ever figure out cause/fix ?
Whenever it seems like it's taking more than 3-4 clicks of the starter motor return the key to the off position and restart it, that's the only way to avoid it. I noticed it only does it when the starter motor really turns over a bunch.
it's gotta be horrible for the engine, good thing it's a dry sump.
