What boost are you seeing? (modified Ecu's)
I'm just wonder if all the tunners play with the same boost levels. What boost are you seeing with your modified ecu's (please, mention all the other performance mods)?
This applies only to the 997TT not the 996TT.
With stock ECU is use to see only 0.9/1.1 bar (normal/sport modes) and only for 1 sec or so.
With my CG ECU I now see 1.0/1.2 bar and it stays there whilst my gas pedal is fully down.
The CG remap is meant to add 0.15 bar more than stock so you are certainly right on my 1.2 figure actually being 1.25 or even higher but the display only showing 1.2 still.
I use a Blitz electronic boost gauge. It spikes occassionally to higher levels, (1,8 to 2.0 bar !!!) but these values are not real and are not taken into consideration
