Recall to lubricate variable turbine?
I got a call today from dealership about a need to bring my car in. Something about lubricating something in the variable turbine system. "Could seize and you'd get more turbo lag."
Didn't sound like a true recall (I did get a recall letter about air conditioner coolant needing to be checked as may be low from factory).
Just curious if anyone else heard anything like this.
That is very interesting. Last week i had a problem with my turbos, which didn´t build any pressure.
Brought it to the OPC and the PIWIS showed a problem with the VTG system which says, that the VTG was "rough-running"
They denied the warranty because of my aftermarket exhaust (no ECU mod!) so i had to pay it myself.![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
Once you alter the OEM configuration of the vehicle, your warranty coverage is at the sole discretion of PAG.
They can claim that since the turbocharger is an integral part of the exhaust design, the modification voided the warranty.
No, it's not common sense, it's a legal view of an OEM warranty.
Unless they can prove that the exhaust caused the fault then they can't deny warranty. That is just the dealers way of wanting to screw you over. This is covered in the Magnuson-Moss Warranty Act.
Guys please realize that this is a maintenance issue. Porsche is checking out each car when they come into service to examine the movement of the vanes.
In '05 in testing 14 of the 16 North American cars had turbine vane issues. It is alot easier on diesel engines since the unburnt fuel lubricates the moving vanes. I am seeing more and more of these units being sent to me for a "clean up" Certain fuel grades or cheaper brands of fuel add deposits which stick to the moving vanes. This causes the vanes to bind, if one binds the entire assy fails.
I think that as time goes on, we will see more notice about these issues. The thig that I am concerned about is the cost that is going to charged in 30K services to repair failed turbochargers. Or better yet, how many warranties are going to be denied..
If any of you guys are getting jerked around at the dealer please email me and I'll be glad to help you>>help your mechanic.
Super Moderator
Needs More Cowbell
Needs More Cowbell
MMWA does not give you liberty to modify a vehicle and then ask the OEM to fix it.
I do agree that it is subject to reasonable acts, but mechanical mods can be litigated in the OEM's favor.....and PCNA loves to litigate.
Unless you are a attorney, you can cry foul all you want. Porsche will deny the claim and push you to litigate. They have the attorney's on retainer. It will cost you more in the end. The exhaust system is a emission device that covers/includes the turbochargers. Installing a exhaust and having turbocharger issues will produce some interesting debates in the near future.
My advice is to "work" with your dealer, and/or find a mod friendly dealer that will make a win-win situation with the labor dollars that you have to spend.
